Old 08-18-2009, 11:28 PM
RichL1967 RichL1967 is offline
Default Brake Line Nuts
This may seem like a simple question for someone who knows but I have been searching the web for an hour trying to find the answer.
M10 x 1.0 nut VS. M10 x 1.0p nut
What does the p stand for ?
I'm thinking something to do with the thread size or pitch but not exactly sure what the difference is.
Thanks in advance
Old 08-19-2009, 07:09 AM
66 LeMans's Avatar
66 LeMans 66 LeMans is offline
I tried google and stuff, but I can't answer your question.
However, I found this on the net.
http://www.boltscience.com/pages/glossary.htm#t
There is an email option there, you might want to ask the question to one of them?
If you do, please post the reply, you got me curious too
I also found this:
http://www.stagonset.co.uk/pictures_..._HexNy_M10.jpg
and this:
http://www.stagonset.co.uk/pictures_...NyHigh_M10.jpg
It's a Type P and Type T nut. All I can see is the P nuts are higher? more threading?
I hope you find the answer
If you don't like the way I drive, get off the sidewalk.
Old 08-19-2009, 12:31 PM
Jimbro727's Avatar
Jimbro727 Jimbro727 is offline
Send a message via AIM to Jimbro727
If I had to guess, the p is indicating that the second number is the thread pitch (distance between threads) versus the number of threads per unit length.
http://www.SheepdogRadio.com
---CARS---
1978 Pontiac Firebird T/A - Martinique blue/blue interior - 400 bored .030 over and stroked with an Eagle kit to 458, SRP forged pistons, Eagle crank, 6x heads, comp cams springs, comp cams hydraulic flat tappet cam, TH-350, and a Jeff Walker Q-Jet.
http://www.cardomain.com/ride/2982177
Old 08-19-2009, 01:20 PM
george kujanski's Avatar
M10 x 1.0...........the 10 is the diam and the 1.0 is the pitch (thread-to-thread distance) in mm.
Don't know what the p would be for, but I doubt if it is pitch since the pitch is already specified.
George
Old 08-19-2009, 01:56 PM
Jimbro727's Avatar
George
Right, I was saying that perhaps the p is just to note that the "1.0" is the pitch, since the second number is sometimes the threads per unit length. In this case, 1.0 threads per mm is the same as a pitch of 1.0, but if it were 2.0, it would matter, since 2.0 threads per mm is a .5 pitch (I think - I'm by no means an expert on this subject).
---CARS---
Old 08-19-2009, 02:09 PM
wrenchmen's Avatar
wrenchmen wrenchmen is offline
I would say they are both the same.
1970 Lemans Sport, PPR 383/4spd.
Old 08-19-2009, 03:45 PM
69goatboy's Avatar
69goatboy 69goatboy is offline
Could the 'p' indicate a pipe thread?
With metric designations whatever comes after the pitch would typically be the tolerance class for that size, however a 'p' tolerance class doesn't exist (at least as far as I know of). Typically you'll see a '4h' or a '6g' or something like that.
Something to keep in mind also is that in the metric world they do use straight pipe instead of taper threads more than us yanks do.
With all of that being said through, I'd guess that it's simply the pitch, as suggested above.
In the metric world, they do not indicate pitch the same way we do. A pitch of "1" simply means that it measures 1mm from crest to crest on the thread profile. Whereas, the Imperial system measures the number of threads over a given measurement. So, your 2.0 pitch would be twice as coarse as a 1.0 would be.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 08-19-2009, 04:41 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Thread pitch is the angle of the threads,nothing to do w/threads per unit. British and or metric pipe threads are designated by a P for parallel or T for tapered.
Old 08-19-2009, 05:04 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
Wrong, dude.....
The pitch is the distance in mm from a point on one thread to the same point on the next thread....as correctly stated above by George and others.....
"XE cam basher"
Old 08-19-2009, 08:40 PM
I'm sure that its safe to say that M10 x 1.0 & M10 x 1.0p are the same thing.
The p stands for pitch and its just redundant that sometimes they put it in there and sometimes they don't.
Thank you one and all.
