Old 08-20-2009, 08:18 PM
indyta1989's Avatar
indyta1989 indyta1989 is offline
Default Admiralty Blue - Dupont base coat code?
Would anyone happen to have a recent dupont number or other cross reference for 1974 Admiralty Blue (code 29)? I called my local dupont automotive paint store and they seem to be stumped as what the cross reference is to a dupont base coat color.
Gary
Old 08-20-2009, 08:43 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
Its the same as 1966 code E Nightwatch Blue. I'm painting a '66 GTO for a customer of ours that is a original code E nightwatch car with Nason base which is a Dupont line. It actually says Admiralty Blue on the code chart on the can. I'm going back out there later and I'll see if there are anymore codes on the can.
_____________________________
www.classicpontiacrescue.com
Super Duty D's Avatar
Super Duty D Super Duty D is offline
I only have a PPG code handy. 29 is # 2526, not sure if that helps.
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
Old 08-20-2009, 08:44 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
code 29 Admiralty Blue is PPG code 2526
Dupont Code 5474L
R-M Code A-2626
here are the links I found for reference:
http://www.tcpglobal.com/aclchip.asp...ntiac-pg01.jpg
http://books.google.com/books?id=jEJ...dupont&f=false
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 08-20-2009, 08:48 PM
indyta1989's Avatar
Thanks Rick!
Bonneville Joe - I would be curious of the codes you have match what Rick has posted?
Gary
Old 08-20-2009, 08:49 PM
Just went out and looked and it just says code E Admiralty Blue. If you have an Oreilly Auto locally just run by there and see if they can get it.
Old 08-20-2009, 08:52 PM
Says 97220 on the top right corner of the label but I don't think that is a paint code. If you are dealing with a reputable paint store they should have a computer mixing system that will give them codes just based on the year make and model color code. If I have someone wanting PPG there is another place I deal with that is totally computerized. If I call him and say I need a '74 Pontiac code 29 it will pull up the name and mix ratio just by the info I tell him.
Old 08-20-2009, 08:55 PM
indyta1989's Avatar
OK, I am hopeful that 5474L is a reference to a dupont base cost and not a single stage. I will pursue that more. I am concerned that the L at the end of 5474L means lacquer. That may be why my local dupont store was stumped, what is the cross reference to a dupont base coat?
Gary
Old 08-20-2009, 10:11 PM
Held for Ransom's Avatar
http://bremsethbodyshop.com/Photos/1...nsAm/index.htm
Contact these guys to see if they remember or have the codes handy (contact info is on home page http://bremsethbodyshop.com/ ).
Old 08-20-2009, 10:29 PM
indyta1989's Avatar
Held for Ransom - thanks, I will give them a call Friday morning to see what they may have code paint codes.
Gary
Old 08-20-2009, 10:43 PM
takid455 takid455 is offline
Send a message via AIM to takid455
I just order some not too long ago. 5474 seems to ring a bell. It is base/ clear. I used Chromabase. cost 70 for a qt. I will be spraying it this weekend. It is the same as midnight blue. Don't be concerned about the lacquer as the paint suppliers account for that (most of the time) when cross referencing. However, if you are trying to repair and area and have it match the original paint, it will be close but slightly off due to aging and chemical properties of the enamel vs lacquer.
Old 08-21-2009, 10:18 PM
5474K is my blend
1972 HO Trans Am auto White/white
1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue
1978 Trans am gold/ black ,T56, t tops, EFI 474,
Build: http://www.pro-touring.com/showthrea...1978+g+machine
1999 30th Trans Am 6 spd, T top
Old 08-22-2009, 08:22 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
I am thinking the last Admirality Blue car i painted,DuPont did not have mix in Chroma Base.I had them take pictures with thier machine of the underside of the trunk lid.I think it came back as an 83 Rolls Royce color.It was dead on correct,as i see alot of these AB cars not quite the right shade.
Old 09-01-2009, 11:59 AM
Blue '66's Avatar
Blue '66 Blue '66 is offline
I had a pint of Admiraliy Blue mixed and had my paint guy shoot it on a small fender patch,I like it.I called a parts store to see if the admirality blue and Nocturne blue were the same (Du pont)the lady told me the 5474 (74) and the 4395L (64) number don't show up in the computer only paint codes?So what are those number for,I got the 4395L out of the GTO Restoration Guide.
Old 09-01-2009, 01:33 PM
superdutybob's Avatar
superdutybob superdutybob is offline
They absolutely are not the same. Nocturne is a little darker than Admiralty Blue. Close but not the same.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 09-01-2009, 02:23 PM
Blue '66's Avatar
Thats what I thought but I was not sure.
