for sale 65 66 67 gto hood oem 1965 1966 1967
for sale 65 66 67 gto hood oem 1965 1966 1967 missing hood scoop insert can ship worldwide too price $350
What year is it from ?
65 66 67 will fit all three
I am aware of what years it will fit , but there is differences . Do you know what exact year it is from ? thank you
no dont now which one exactly its from ok
here are a couple things to look for to distinguish the difference:
1965: no holes on middle lip up front for arrow emblem because on 65 it was located on the "T" bar, also there are studs sticking out of the back on each side to mount hood to hinges. 1966: had arrow emblem on the nose of the hood so there will be 2 holes present for this emblem (unless filled in by previous owner) 1967: had arrow emblem on the nose of the hood so there will be 2 holes present for this emblem (unless filled in by previous owner), no studs in the back for mounting to hinges, this year bolts were used to bolt hood to hinges. Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
Mark is correct there is a difference!~! Larry B,
Mr. President, you can't say Dallas doesn't love you " |
Great information . . . I learned something here.
Steve |
Is this hood still available? and if so, what year is it based on the info posted above?
Thanks, John |
