Old 10-05-2009, 08:53 PM
Lightfoot's Avatar
Default Very low water volume from my kitchen faucet. What would cause it?
This is also evident at my bathroom sink.
When I turn one valve (either hot or cold, doesn't matter) all the way open, the water flow is what I would estimate about 30% what it should be.
And here is the part that irritates me: When I open the second valve wide open, it doesn't increase water volume the slightest bit.
It isn't the airiater. It's just lousy water volume. When I try the rinse hose, it seems to have halfway decent pressure, but I don't know if it is because of the restricted opening. Like putting your thumb over the end of a garden hose.
It seems like a restriction in the supply pipe would cause the same effect. A small amount of water at a high pressure. Not so, if the pipe is clogged farther down? (upstream)? I am on the second floor, a half storie above ground level.
I will add that my toilet takes a long time to refill the tank. Over three minutes.
But my shower seems to have good pressure & volume. So I don't think it could be a weak well pump. Actually, I think we are on city water anyway.
I live in an apartment complex with 17 units in the building. I need to tell management about this, but I would like to know what I'm talking about before I bring it to their attention, so if they try to blow me off, I can have an argument ready.
The volume was low when I first moved in (and I put up with it), but it seems to have gotten considerably worse in the the last six months.
Any plumbers out there?
Seeking recovery of my stolen 1988 Buick LeSabre T-type. Primary summer driver & Road Trip car.
Garnet Red with 2007 PENDOT inspection stickers on windshield. Had minor damage to left rear quarter & bumper. Last three of VIN: 301
Could be being driven with altered VIN.
Bodywork on left rear quarter (near the tail light) would be a tip-off.
Last seen by a patrol officer doing a routine plate check in Gary, Indiana, August 31, 2009
(The thieves were driving, but my plate was clean.)
Old 10-05-2009, 09:32 PM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
Light....I'm no plumber BUT I have the same problem with the bathroom sink but not in the kitchen. The kitchen faucet works great. It seems like a flow restriction to me but its pure speculation on my part.
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
Old 10-06-2009, 06:20 AM
Txbobcat Txbobcat is offline
Filter is cloggng up remove and clean usually in the end of the faucett where the water exits. Unscrew it and look for debris
Old 10-06-2009, 06:25 AM
Thanks TX...I'll try that too.
Old 10-06-2009, 07:22 AM
Tex...Thanks...I took the screen off and there was platic restrictor with tiny holes in it that was plugged with sediment. I left that out; reinstalled the gasket and screen and have 100% flow now...THANKS!!
Old 10-06-2009, 09:10 AM
sleepy's Avatar
sleepy sleepy is offline
The owner probably put low flow (restricted) fixtures in. Most apartment dwellers don't have to pay sewer and water(the owner of the building does) and he is trying to keep the bill down.
Why is he not suspended?
Old 10-06-2009, 12:58 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Can't buy them without restricters in my neck of the woods. Shame when the vegtable sprayer has more output then the taps
Old 10-06-2009, 01:08 PM
69goatboy's Avatar
69goatboy 69goatboy is offline
They usually get clogged with sediment when there has been some plumbing work done somewhere upstream, either in the house itself or from the water supply from the street. Even when the fire department tests the hydrants can cause it.
There is sediment in every pipe system, shutting off valves and turning them back on will disturb the sediment, and some will eventually make its way to an egress.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 10-06-2009, 03:06 PM
Bjorn's Avatar
Bjorn Bjorn is offline
I have a "whole house" filter in my Utility room , that I change out 2 to 3 times a year...lots of sediment....
old rusty pipes and sediment....
glad you found the problem.....
usually I can tell when our filter gets to the change time...if we run both showers , "normally" its ok , when second shower trickles if first is on , time to change filter out.
FireBjorn
http://FirstGenFirebird.org/show/closeup.mv?CarID=221
breathe and enjoy it , life is temporary
69 Firebird convertible
71 Triumph TR6
Old 10-06-2009, 03:29 PM
Lightfoot's Avatar
Guys, it's not the screen/airiator in the end of the faucet! As I stated in my first post. If it was, I would not have needed to start this thread, as I am used to cleaning those a couple times a year, from a previous apartment that had really high iron content in the water.
I tried it with the screen removed and it made no difference. Same piddly amount of water. It should not take 15-20 seconds to fill a six ounce glass with the both valves WIDE OPEN.
And I asked my neighbor across the hall; he said his runs normal.
I will ceck under the sink tonight to see if the rinse hose is tapped in much lower than the spigot. Maybe there is a section of pipe between the hose connection and spigot that could be clogged.
Old 10-06-2009, 06:09 PM
Sometimes there is a filter right at the bottom that you hook the water line to. Or even clogged wher the line connects from the real plumbing and sometimes not.
Old 10-06-2009, 08:41 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
Is yours an older building with galvanized iron pipes? They tend to clog up with corrosion over time. That's a big repair. Other things to check: The shutoff valves under the sink might have junk in them. Be careful, they are notorious for being seized up or having the handle break off in your hands. Unlikely, but the main shutoff valve for the apartment may be partially closed. This is really a job for the apartment management's plumber to take care of.
http://www.pontiacpower.org/
Old 10-07-2009, 01:43 PM
69goatboy's Avatar
Check your vent stack through the roof. Sounds like you have air trapped in the system somewhere.
Squirrels storing walnuts for the winter?
Don't laugh. I pulled a extra large walnut from the exhaust vent pump on my furnace last year. It was so large, it was preventing the furnace from operating.
I now have a new furnace, and the tree that the squirrels were using is in fireplace pieces now.
Old 10-07-2009, 03:21 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Did you pay the bill?
Sorry, I had to.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 10-07-2009, 03:29 PM
The Boss's Avatar
The Boss The Boss is offline
HUH?
The vent through the roof has nothing to do with the H/C supply lines - if his shower wasn't draining, you might be on to something.
And go racin' in the street.
Old 10-07-2009, 04:01 PM
Bjorn's Avatar
incoming water is clogged somewhere...if theres no filter , its in the line...since its an apt and the other(s) tenant has flowing water...
its a apt owner repair or maintenance , call the mgr or owner.
FireBjorn
71 Triumph TR6
Old 10-07-2009, 04:09 PM
69goatboy's Avatar
HUH?
I had drain lines on the brain from a different project.
If it's not a clog, it still sounds as though air is either trapped in there or there is a leak somewhere robbing the pressure.
Old 10-09-2009, 11:16 AM
Stuckinda60s Stuckinda60s is offline
Does the water flow start at a higher rate and quickly reduce to a trickle? That would signify a restriction in the line before it gets to the faucet.
Look at it this way. The flow is restricted, but it will still, over time, build up to the pressure in the main line. When you open the tap, the high pressure pushes the water out quickly but reduces the flow because of the restriction.
Does the rinse hose produce more volume than the faucet, or does it take a similar amount of time to fill a glass? The rubber hose, like a garden hose, will act like a bladder, stretching a little and storing a little more water at the higher pressure, but the final result would be the same.
A couple of possibilities. There may be a valve off the main line which is throttled or there's a restriction in the common line between the main and the faucets in your apartment.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 10-09-2009, 01:15 PM
Lightfoot's Avatar
Rich, the pressure/volume is low right off the get go.
Last evening I did some testing with a second hand, to get a better description, and to prove to myself that the volume is better through the rinse hose, etc.
Filling a 6 cup sauce pan, It took 79 seconds from the faucet. With the rinse hose, only 24 seconds.
Looking under the sink, I found that the rinse hose 'connects' directly underneath the base of the faucet. Both feed lines go directly to the underside of the valves.
I also came to the realization that the rinse hose is always pressurized, at any time the valves are open. No brainer, but I never thought about that before.
Thought there was some kind of diverter valve under the faucet, that closed when you squeeze the hose trigger.
Anyway, I have figured out that there is (must be) restriction in the short section between the sprayer takeoff & faucet, or in the faucet passageway itself.
Bottom line: the whole faucet fixture needs replaced.
At least I know what to tell managment now. They don't have to tear open walls, or dig to replace pipe sections.
Thanks everybody, for all the input.
