Old 10-11-2009, 10:35 PM
stucky2947's Avatar
stucky2947 stucky2947 is offline
Default dash lights with no place to go
I'm trying to button up the wiring on my 62, and I have three wires with bulb sockets on them and have no place for them to go. They are in the dash harness (new from M&H), there is a black wire, a dark blue wire, and a tan wire. All of them have light bulb sockets on the ends and I don't know where to plug them in. I have a color schematic and it does not show these wires. I started the car and turned and pulled every knob and they never came on. Any ideas??
Old 10-11-2009, 10:55 PM
Single wire going in the sockets?
Old 10-12-2009, 12:33 AM
I see single wire dark blue for right turn. Single wire black for lighted ignition switch. Still not seeing a single wire tan.
Being single wire, they will have to be grounded to work.(that was just in case )
See if this diagram has anything different than yours.
Name:	62 Pontiac Full Size.jpg
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 10-12-2009, 07:45 AM
stucky2947's Avatar
I have the one for the right turn signal. I put a gray wire to the ignition light , but I WILL replace it with the black, as I am short one gray wire light for the instrument cluster. I'll check the other blue to see if it works with the turn signal also.
Old 10-12-2009, 08:34 AM
Diagram shows it, but, ground the black and make sure it comes on with the lights before swapping.
If it was newer, I'd say tan was e-brake, brake failure light, or maybe low fluid.
IDK Just have to try them.
Poncho & Lefty
