Old 10-29-2009, 09:38 PM
gto mike gto mike is offline
Default 67 gto-back up switch hook up
Just mounted a back up switch on my 4-speed trans ran the wire up to the firewall and really have nowhere to plug it to.I have a new dash harness installed from Ames.There's one plug that looks like it should go to but its a female plug & the back up switch plug is also female.I'm I missing something here?Where else can I plug the back up switch into??Tail lite harness??Thanks Mike
Old 10-30-2009, 06:10 AM
Jeff Hamlin's Avatar
The lead for the BU sw should run up into the interior via the shifter hole.
The tie in is from under the dash.
The Dk & Lt Green leads are the source. I don't recall a plug connetor, so you may have to mod you connections.
