Old 11-15-2009, 05:02 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Default Ideas to get a trunk Open??
Trying to get the trunk open on a '73. The lock cylinder is still in it but the center has been knocked out. I've never had to do this before so any ideas on how to get it open would be greatly appreciated. The drivers side taillights are not mounted so I have a way into the trunk from that side. I played around with a screwdriver but that didn't work.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 11-15-2009, 05:27 PM
Father&Son73T/A Father&Son73T/A is offline
Got a hammer?,............no sorry,just jokin,...can you get in from inside the rear seat,I think a c-lock or nut needs to be loosend from inside?...I can go out to look if needed,sorry cocktail in hand right now...........
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
Old 11-15-2009, 05:33 PM
SD73's Avatar
SD73 SD73 is offline
If the lock is totally ruined anyway, you could drill straight through it. There is a steel shaft that goes into a slot after that. You can remove the shaft then use a long screw driver to turn the slot and pop the trunk open. This is the way of the junkyarder. I've never tried F&S73T/A's way, so you may want to try that first.
Old 11-15-2009, 05:36 PM
OK,that was a stupid comment after I went outside to look,but base that on this Mexican Matador I'm drinking right now,6-7 inch flathead from outside of cylinder should work....
Old 11-15-2009, 05:39 PM
2manyT/A'S's Avatar
Look inside where lock cyl. was & if you can see a slot,try turning it with a medium sized slot screwdriver.
Also look for a thin flat rod. You may be able to turn it with needle nose pliers.
If you remove rear seat backrest cushion,the latch bolts can be accessed.
You need to put ALL of your extensions together for this one.
Once it's open,then lock cylinder bolts can be removed from the inside.
Old 11-15-2009, 05:42 PM
Red face
yeah,yours and your neighbors extensions from inside,unless your 85 lbs wet.
I didn't realize how small it is till I looked.
Old 11-15-2009, 06:06 PM
Txbobcat Txbobcat is offline
I have a 3 foot extension for that problem.
Old 11-15-2009, 06:51 PM
Wink
Without the use of "Extenze?"
......bragger....
Old 11-15-2009, 07:38 PM
Ummm, wow!!
Ok, thanks for all the instructional help!! I'll give these suggestions a whirl and let you guys know.
Jimmy
POCI - AAC
Old 11-16-2009, 12:22 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
If you have to use more than one extension, make sure you tape them together just to make sure they don't come apart...
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 11-16-2009, 02:01 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
I've used all the mentioned ways and they all work. Probably the safest way to not damage the car is the removal of the seat back rest and go in with a super long extension and remove the latch off the decklid. Once inside you can go in and remove the retainer off the cylinder and replace it with a new assembly. You should be able to get the latch back on the decklid in the right place just by looking at the paint lines and the bolts in their proper location based on where the washers left marks on the decklid.
_____________________________
www.classicpontiacrescue.com
Old 11-16-2009, 05:59 PM
GRNMTGOAT's Avatar
GRNMTGOAT GRNMTGOAT is offline
Try this, you say the drivers side light is out, if you reach in from the light opening until you can feel the hole in the lock center, stretch one inch further and you will feel a small square tab, press this down and it releases the latch. I just went out and tried it, however, there is no lock in mine at present, so it MAY be different but worth a try, its a good stretch !! Regards Bruce.
1970 T/A RA3 #'s match.
Old 11-18-2009, 03:26 AM
Cool!! Will def give that a try. You guys have given me several good ideas to go by. Car is in storage, should be able to get out to it in the next day or two and will let you know how it goes.
Jimmy
POCI - AAC
Old 11-23-2009, 11:19 PM
lawbreaker2's Avatar
lawbreaker2 lawbreaker2 is offline
Take a flat head and duck tape it to the end of a broom stick and remove the back seat and go that way, works for me everytime, HAHA I had to do this at the TA nats years ago when I locked my keys in the trunk, Don't ask why or how I did that.
Old 11-24-2009, 05:43 PM
Wink
Mr.Miller,Budweiser or Mr.Jack I presume.............
Old 11-25-2009, 11:44 AM
blue71ta's Avatar
blue71ta blue71ta is offline
Yep, I've used this method myself on a '72 GTO, works well...
