Old 11-30-2009, 07:24 PM
Tom Vaught's Avatar
Boost Engineer
Default Pontiac - Boost Links
Some Boosting Links you may not be aware of:
Superchargers:
1) http://www.vortechsuperchargers.com/
2) http://www.procharger.com/
3) http://www.magnusonproducts.com/
4) http://www.eaton.com/EatonCom/Produc...gers/index.htm
5) http://www.paxtonauto.com/
6) http://www.kennebell.net/
7) http://www.whipplesuperchargers.com/
8) http://www.blowerdriveservice.com/
9) http://www.bellengineering.net/
Turbochargers:
1) http://www.turboneticsinc.com/
2) http://www.precisionturbo.net/
3) http://www.turbos.bwauto.com/
4) http://www.turbobygarrett.com/
5) http://www.ihi-turbo.com/
6) http://www.bullseyepower.com/racing.asp
7) http://www.extremepsi.com/store/customer/home.php
Old 11-30-2009, 08:41 PM
Kurt Zimmerman's Avatar
Kurt Zimmerman Kurt Zimmerman is offline
Tom,
I made this a sticky because it looks like a great resource. Any other boost related links can be added.
Kurt
Old 12-01-2009, 03:10 PM
Turbo Calculator
Turbo Java Calculators
Turbo 101
Turbo Tech 103
Old 12-04-2009, 07:14 PM
Tom Vaught's Avatar
Boost Engineer
Another GOOD Turbo Link:
http://www.gnttype.org/techarea/turbo/turboflow.html
Tom Vaught
Old 12-11-2009, 10:11 PM
Tom Vaught's Avatar
Boost Engineer
Another good Turbo Knowledge Link:
http://www.grapeaperacing.com/tech/turbochargers.pdf
Tom Vaught
Old 01-07-2010, 06:16 PM
Tom Vaught's Avatar
Boost Engineer
This link
http://www.stealth316.com/2-turbotemp.htm
will allow you to imput:
1) Input Air Inlet Temperature to the compressor
2) Input Air Inlet Pressure to the compressor
3) Input Compressor Discharge Pressure from the compressor
4) Input Compressor Efficiency
It will then calculate the Compressor Discharge Temperature, The associated Pressure Ratio from the input data, and the Air Charge Density Ratio.
It will additionally Load the calculated results into the Inter-cooler Calculator portion of the program.
5) You can now input the Inter-cooler Efficiency (Example 8-%)
6) You can change the Inter-cooler Pressure Loss (hopefully less than 1 psi)
7) The last value to be inputted is the Ambient Temperature: Outside Air Temperature
if using an Air to Air Inter-cooler and the water temperature if using a Water to Air Inter-cooler. (Example 32 degree F Ice Water)
I use this program all the time at work. It seems to match reality very well.
Tom Vaught
Old 01-08-2010, 12:36 AM
Nice link Tom!
All these years I've been doing the math longhand! I'll be using this one.
Heres a few links
http://www.dsmtuners.com/forums/turb...et-turbos.html
Lots of info on Holset turbos for the DIY guys
http://victorylibrary.com/mopar/blower-c.htm Lots of info related to supercharging
http://www.ststurbo.com/ Noted for rear mounted under car turbos
http://www.hamptonblowers.com/ Roots blowers from one of the best in the business Don Hampton and he has kits for Pontiacs.
http://www.dyersblowers.com/ Roots blower kits for Pontiacs
http://www.goodvibesracing.com/index.htm Specialize in Blowers and mechanical fuel injection
http://www.pre-luber.com/index.htm the name says it all
http://www.stockcarproducts.com/acc17.htm Air density gauge real handy tool at the track. This link also tells you how to use it.
http://www.superchargerusa.com
http://www.tialsport.com/products.htm Wastegates, blowoff valves, and turbos
My favorites folder resembles everything posted so far. I have more but need to reorganize my supercharge folder, its getting too big.
Old 01-26-2010, 10:52 PM
Tom Vaught's Avatar
Boost Engineer
More good links and calculators:
x http://www.csgnetwork.com/automotiveconverters.html
x http://www.csgnetwork.com/blowerhpcalc.html
x http://www.deltainstrumentation.com/calcs.html
x http://www.themeter.net/conv9_e.htm
x http://www.unitconversion.org/unit_c...flow-mass.html
x http://www.unitconversion.org/unit_c...w-mass-ex.html
x http://www.angelfire.com/on/geebjen/pontiac.html
Tom Vaught
Old 11-05-2010, 12:16 PM
Borg Warners Interactive Compressor AND Turbine match. Very good, intuitive learning, neat help format.
http://www.turbodriven.com/performan...bot/index.html
Old 03-17-2011, 12:07 AM
7secjudge's Avatar
7secjudge 7secjudge is offline
other sites for blowers
- RBS superchargers (jr) www.rbssuperchargers.com
- The Blower Shop (eric) www.theblowershop.com
- Good Vibrations (matt) www.goodvibesracing.com
-Dmpe superchargers (darren) www.dmpeinc.com
these are good shops and great people to deal with honesty and know what there talking about. dmpe and the blowershop is for the very serious racer there parts are top of the line. we run a blower Shop Blower and are very pleased with it.
Ron
Old 11-06-2014, 12:47 PM
wreckmastr's Avatar
Another fuel management system. Great piece we have been testing on a friends car and it is impressive. We will be switching from BigStuff 3 to Fuel Tech the over the winter
http://www.fueltech.net/
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 02-28-2016, 09:22 PM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
Default another one if you thinking gear drive
www.cachassisworks.com
they have a set up for the AllPontiac block.
Old 11-30-2019, 07:52 PM
AIR RAM AIR RAM is offline
Pontiac Turbo Manifolds
Stainless Headers Manufacturing
https://www.stainlessheaders.com/pro...5_Turbo_Header
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
