Cleaning out the shop!!
The time has come to get all my stuff out of my friend and builder, Chad Fletcher's shop!
Below is much of the "take off" stuff from my 71 Firebird Formula 400. Let me know if you are interested in any of the below by email me at ty.ingle@us.af.mil V/R, Ty Holley 750 3310 Shaker455-modified $250 +s&h Unmodified Edelbrock Performer Intake $100 +s&h Hughes 2500 stall converter $150 +s&h TH350 w/ TransGo shift kit $300 +s&h 1971 Radiator Support $200 +s&h 3-core Radiator $150 +s&h 71 Fenders $100 ea (3) +s&h Inner Fenders $50 ea (3) +s&h Stock Glass front & rear $100 +s&h Rear deluxe seat belts $50 (2) +s&h Trunk lid and filler $100 for both +s&h Door jamb vent grills $20 +s&h Console Glove Box assembly $20 +s&h Rear Console Cover Plate $10 +s&h Stock front grills $150 +s&h Stock headlight bezels $100 +s&h Stock Park Brake Bezels $40 +s&h Stock taillight lenses $100 +s&h Repop taillight bezels $100 +s&h Front and rear sway bars $100 +s&h Stock M/C? make offer Stock manual disc/drum brakes? make offer Stock a-arms? make offer stock front steering assembly? make offer used kyb shocks (4)? make offer stock rear springs? make offer HO racing front springs (550lbs)? make offer 71 steering column? make offer Formula steering wheel $100 +s&h Performer intake... modified with heat crossover removed, water crossover separated and included... aluminum block off plates for heads included! $150 +s&h Lakewood Slapper Bars $20 +s&h... old school but they still work! Firebird Jack, Base and wrench $50 +s&h What I paid for it off eBay... just never got around to cleaning & painting it. 2000-2200rpm Torque converter $100 +s&h Worked great in my 71 Firebird 400/TH350... great street converter! Crane Fireball II Factory "N" replacement 335hp cam (968771) $50 +s&h This cam and lifter set have less than 10,000 miles on them! GM 10-bolt differential and 2.73 gears $50 +s&h Stock unit that came out of my 71 Firebird GM Points Distributor... HO Racing "accuracy" kit installed $50 +s&h Dave Ray GM Distributor converted to MSD trigger for that stealthy approach $100 +s&h Driveshaft safety loop $20 +s&h Like new... never installed... Lakewood style Original rear taillight wiring harness for 70-73 Firebird $25 +s&h May fit later models also... Holley 70gph mechanical fuel pump (HLY-12-837) $35 +s&h Carter Street Super Mechanical Fuel Pump 120gph $100 +s&h Bullet 224/230 .485/.491 110LSA cam and lifters (used) $100 +s&h - this custom grind made great power in my 400 w/#13 heads! Pontiac 400 crank, stock rods, .030 pistons (used) $150 +s&h
US Air Force Retired "FREEDOMBIRD" |
is the jack, base & wrench correct for a 71 ?
hows the condition of the tailight wiring harness ? what color are the rear seat belts ? is the formula wheel original to the car ? if so, what condition is it in ? i may also grab the driveshaft safety loop depending on the other "stuff" thanks - tim |
Parts...
Jack etc was an eBay purchase but I can get the numbers for you if you want!
Wiring was all working when we took it out of the car... replaced with AAW. Black seat belts with deluxe buckles... Not the original wheel... eBay deal I restored... brushed the center spokes with 400 and sprayed a coat of Plasti-Dip on the rim. Looks great! Worked Great! Let me know if you have any more questions! V/R, Ty
email sent
1972 HO Trans Am auto White/white 1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue 1978 Trans am gold/ black ,T56, t tops, EFI 474, Build: http://www.pro-touring.com/showthrea...1978+g+machine 1999 30th Trans Am 6 spd, T top |
thanks
