Old 12-13-2009, 06:54 PM
drevil1's Avatar
drevil1 drevil1 is offline
Default need advice on new combo
I could use some help with a new engine that I recently bought from another member here. It's a 73' 20 over 400. Stock crank and rods, balanced and assembled. It has stock 87cc edelbrock heads/arp bolts. Installed is a comp 280ah-10 flat tappet hyd.The motor is fully assembled and complete ready to install. I am putting it in a 69 gto conv.It has 3.55 gears, th400/2200 stall, and I plan on using my rpm intake and holly street avenger 770 carb. Of course I just recently bought d port headers,figures.My main concern is the cam, which is comps RA IV. I don't take the car to the track, or race it. But I do drive it HARD. I currently have the Crower 60916 cam in the original engine,with rpm and holly on top,acell electronic dist and headers into 2 1/2 exhaust.I like the "personality" of the engine as it is but would like more "freight train" since I now have the e-heads. I would consider the crower cam pretty tame but decent.
So basically what I am asking is what would be a better choice of cam for this combo, than the comp cam already installed.I was originally going to just throw it in and run what was in it , just to see. But I don't think I have enough stall, or gears, and I would prefer a broad flat torque curve as opposed to a high rpm race engine. I don't want to go too big and lose my lower rpm power, and I'm afraid of leaving too much on the table and not using the potential of the heads.
Also what headers, or RA manifolds would be best. I have only been able to find 2 headers for round port . Dougs, and Hooker super comps. Is that all there is ?
Oh the pistons are flat tops, forged. I was told this motor was built to be about 9-9.5 to 1 compression.
Her is a link to the ad from which I bought the motor. Paul the seller is a great guy and was very helpful when I went to pick up the engine. http://forums.maxperformanceinc.com/...d.php?t=615687
Thanks in advance , and sorry for such a long post.
A pic of the cam card for the cam in the motor .
Old 12-13-2009, 10:28 PM
vtxman's Avatar
vtxman vtxman is offline
On the surface, the biggest problem with your combo is your compression ratio. Typically the 87cc heads are used for a 455 or larger engine. Here is a calculator you can use to determine the compression ratio.
http://www.wallaceracing.com/cr_test2.php
This is what I came up with:
Your displacement is 404.04 CID
The Compression Ratio is: 8.86
For an aluminum headed engine, I would want closer to 10 or 10.5-1 compression ratio. The RA IV cam would be a great choice if you had more compression. With what you have, you would have very little lower rpm power. I would choose the Crower cam if you were to run the lower compression.
I see two other options. First is to obtain a cylinder head with 72cc chambers. The second is to obtain a stroker crank. (4.21 stroke) Either of these options will get you to 10:1 compression and then the Comp Cam would be a great choice.
JMO
79 Trans Am 400 4 spd WS6
68 Firebird 400 Convertible
70 Pontiac GTO
2007 Pontiac Solstice
Old 12-14-2009, 06:47 AM
drevil1's Avatar
I went to wallerracing and ran the calculator. It's very easy to manipulate the end result just by changing gasket thickness, deck height, and other options. It's very possible the cr is 9-1 as I was told. Assuming 9-1 cr ,do you think that crower cam is the best choice for a 400 with e-heads? I thought that crower cam, the 60916, needed closer to 10-1 cr. I also have a comp cams xe268, but thought it would be too small.Is 9-1 cr too low for aluminum heads?
Thanks again.
Old 12-14-2009, 07:19 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Unless the engine is zero decked with two valve relief pistons and thin head gasket, it's probably down around 8.5-8.8 to 1 compression, could be even lower than that.
In an case, the 87 cc heads are not the "hot" ticket for the 400 right to start with. Huge runners, big cam, and low compression aren't going to produce a 1hp/cid engine with tons of low end and mid-range power.
You need at least 10 to 1, near 11 to 1 would be better, to effectively use the RAIV size camshafts. The problem with using smaller cams with the lower compression ratio, is that you are not utilizing the potential of the big runner Edelbrock heads.
+1 for the previous post. A 4.21 or 4.25" stroker kit would be the best option, IMHO. This would cover the compression ratio deal, and allow you to effectively use the cam you have already chosen......Cliff
Old 12-14-2009, 08:59 AM
drevil1's Avatar
UHGG!! I only bought this motor because it was machined and assembled ,done. Fwiw I didnt choose the raIV cam, it came in the motor as I got it. I guess I need to pull a head off and see where the deck is, and what head gaskets are on there. I will attempt to cc the heads also, maybe they were cut? I hadnt really thought about the cr being too low, just going on what I was told. I thought I could just find a better cam for my application. I will report back with my findings. Thanks, Joe
Old 12-14-2009, 09:14 AM
Cliff R's Avatar
The RAIV sized cam requires at least 10 to 1, 11 to 1 would be better, in the 400 engine. The engine will be a real "turd" if you don't raise the compression ratio, and/or install a smaller cam.
Put it this way, my engine in the signature below, uses 76 cc aluminum heads, flat top JE pistons with 2 valve reliefs, and a 236/245/112 camshaft. It also has 455 cid, right at 11 to 1 compression ratio, and I wouldn't even consider less compression for that particular combination of parts.......Cliff
Old 12-14-2009, 10:25 AM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
DrEvil,
Another viable option would be to find the 72cc E-heads. They'll bump your CR up to 10+:1 on a 400. Lots of guys doing 455/stoker based combos would buy your 87cc heads. You may still want a cam change but that's much easier than pulling apart your bottom end for a crank swap.
Stu
Edit: I see vtxman already said that.
Old 12-14-2009, 02:54 PM
Cliff R's Avatar
Good advise Stu, and probably the best route to go considering the situation......Cliff
Old 12-14-2009, 04:24 PM
drevil1's Avatar
Just got home from work, having a cup of coffee then out to the garage. I will let you know what Ive got.
I would definately swap heads with someone before taking the motor apart. Picture me a month ago explaining to my wife how this motorwas what I needed, and now telling her I have to buy a crank and rods while Im in there. She'll kill me in my sleep.
Old 12-14-2009, 06:44 PM
vtxman's Avatar
I can totally relate. You may need to practice sleeping with one eye open........either that, or get real good at hiding parts in the garage where she won't find them. But then again, she will probably see the credit card bill. What to do......isn't this fun!
Good luck with your build!
70 Pontiac GTO
Old 12-14-2009, 09:02 PM
drevil1's Avatar
Here's what I found.
1: Pistons are TRW L2262F .030 not .020 like I thought. 4 valve relief 6.7cc
2: FelPro 1016 head gasket .039
3: Block decked to .010 - .012
4: Heads dont appear to be milled, but I really don't know. I took some pics if anyone can tell from the surface or from the comb. chambers. I need a more accurate measuring cup, mine showed almost 100 ml to fill a chamber. That can't be right.
Conclusion with 87cc heads and the #s above I get 8.96 cr.
If I change the head gasket to a .035 thick, I get 9.03 cr.
If I changed heads to 72cc edelbrocks with .039 gasket, I get 10.29 cr.
Is there really that much of a difference from the 9-1 cr to 10.29-1 cr ?
Let me ask this way; Can the new motor with 87cc e-heads at 9-1cr ,have more power/torque than my existing motor, iron head 10-1 cr ,60916 cam ?
Thats what I'm after. If it can't be done at 9-1 cr, I will look to trade heads.
At least I have the whole winter ahead of me. Thanks again.
ID:	190900   Click image for larger version
ID:	190901   Click image for larger version
ID:	190902   Click image for larger version
ID:	190903   Click image for larger version
Old 12-15-2009, 09:23 AM
HWYSTR455's Avatar
What kind of iron heads do you have? What's the condition of the engine you have in the car now? Is the '72 block a thick web block? (most likely) How about the one in the car now?
You could run the engine the way it is now, it would run good, and make good power. It's not optimum, but not terrible by any stretch. You will probably be surprised at how much timing it wants!
The heads are fresh, and would be easiest to barter or trade for 72s, BUT, you may want to hang on to them if you plan on doing a stroker in the future.
You could freshen up the iron heads and throw them on the fresh short block, drive it, and do a long-term stroker build on what you pull out of the car. And in that combo, you could choose just about any cam and target any characteristics you want. You could open the ring gaps a touch and spray the heck out of it! Heh-heh! (don't let anyone shy you away of making power because of the rods either).
You have an engine for the rotation now! Heh-heh!
Old 12-15-2009, 12:23 PM
goatman-68's Avatar
goatman-68 goatman-68 is offline
Default combo
I have a 400 +030 and have the 87cc E-Heads. Only difference is I have the L2279F30 pistons which are domed. My block was zero decked and after I massaged the chambers to get rid of possible hot spots I have close to 89cc. With the pistons I have and the heads it calculates out to about 10.4cr. It is a possible option if you want to keep the heads.
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/[email protected] 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker.
Old 12-15-2009, 05:41 PM
drevil1's Avatar
HWYSTR455, the whole reason I'm changing the motor is because it is original #'s matching. 69 ys 400, 62 heads. I want to store it away and take it out of rotation. I would throw my 62's back on the new motor if the 87cc e-heads dont work out. I really cant do the stroker deal now. When I do , it will be forged crank and rods, prof.built. which leads to my reply to goatman-68. I dont have the skills to "build" an engine. I can do cams and bolt on stuff, no problem. I just dont have any experience with bearings, rods,crank, rings, and all the required clearances and little tricks to succesfully assemble a motor.I wish I did, I just can't afford to make one little mistake that would most likely cause the motor to fail. I think you have a proper setup or combination, and if my motor had the right combination the first time, it probably would not have been for sale. I appreciate all of your opinions and advice.
Obviously if you get enough opinions, you are going to hear what you want. I understand aluminum heads can handle higher compression. It is not the optimal setup, o.k. If vtxman had not caught the fact that I had such low compression, I would have never even questioned it. Cliff has made it clear he would like to see 10-1 or better. But for right now, I need to make the best of this setup at 9-1 cr. I would like to hold onto the heads for the future, and try and make them work now. I am willing to go with a hyd. roller setup if that helps my chances. If it did in fact turn out to be a "turd" because of the heads I will throw my 62 heads on, and either trade the heads for 72's or start collecting forged stroker parts. Maybe there is a hyd roller that will make this combo work . Anybody know? Thanks, Joe
Old 12-15-2009, 06:12 PM
taalltheway taalltheway is offline
I think the problem is that everybody here seems to compare your combo with a theoretical optimum engine. I think waht you have is pretty decent. With the stock rotating assembly you should not rev it too high anyway so a big cam will not give you the best results. They make their most power a very high rpms. What you have is a good stockengine with good flowing heads. I would consider going to a much smaller cam. In my experience a RAIV-cam has good driveability in a 455 but is too wild for a 400. Pontiac put these cams only in the wildest manual transmission 400s for a good reason. If you want the "freight-train"-characteristic with punch down low you need a smaller cam. Here you have two options:
1. Rhoads lifters
The will make your cam act about 10 degrees smaller at lower rpms but restore all the glory above 3500 rpms.
2. A new smaller cam that should be around 220@0,050. I would even consider the much criticized Comp cams for your engine since they tend to increase dynamic compression in low compression engines.
I am sure from my experience that your engine will produce much more power in the low- and midrange where a driver usually operates the engine 95% of the time. It will feel much stronger and will not need a high stall converter.
This would be the cheapest fix for your problem. I would keep the 87cc-heads because if you want a real powerful engine you will have to go to forged internals. Once you do that buying a strokerkit is not more expensive than staying at 400 cui and with the popular 462cui-kits your 87cc-heads would be right on the money. So keep them for your future expansionplans. Otherwise you will have to swap heads again. And keep you RAIV-cam for the bigger future engine too.
Old 12-15-2009, 06:17 PM
vtxman's Avatar
Your combination with 8:5 - 9:0 CR will work, it just may not reach its full potential.
After 1970, the factory lowered the compression for emission reasons etc. It's just that the Ram Air IV cam is not designed for the lower compression, and will be a "turd" in a 400 with compression under 10:0 to 1.
Given your situation, your best option would be to make a careful Cam selection that will compliment your combo. There are High Performance cams designed to work with lower compression engines. These cams are generally smaller cams that generate additional cylinder pressure to compensate for the lack of stactic compression.
I am not an expert on these cams, but I do believe the XE grinds from Comp are designed and work well when lower compression is used. The XE 268 comes to mind. Again I have not used these cams myself, but read a lot about them.
I would reach out to "Screaming Chief" or "Mr Pbody" for help with a cam selection. I believe Mr Pbody has a lot of experience building engines using the Comp XE cams.
I would not use the Ram Air IV cam. I understand that the Crower 60916 has worked in similar combinations and is not as sensitive to compression ratio.
70 Pontiac GTO
Old 12-15-2009, 07:04 PM
drevil1's Avatar
taalltheway and vtxman, both of you basically saying the same thing. Maybe not perfect but it will work. I'm cool with that. I already have in my car now, the Crower 60916 cam which is 221/229 @.050. I put that in to replace the comp cams xe268, which was in the motor when I bought my car. I like the Crower better, but it might be a different story with lower cr and alum heads.? If nobody has a sugestion for a roller that would make this a better motor, I should try using what I have at least to have something to compare to. I never really thought the raIV cam was right for my combination. And the other 2 are low miles, but broken in. I also have a set of rhoads lifters, and different ratio rockers.
I actually bought the Crower cam after hearing Cliff R and others praising it. Joe
Old 12-15-2009, 11:05 PM
mechanic17 mechanic17 is offline
So throw it back together with the xe268 and burn rubber. I don't think you need to use the rhoads with that one, so save 'em for the RAiv when it goes in something else. I ran a 400 at 8.0 to 1 for a few years on the street and it was still strong.
Old 12-16-2009, 08:48 AM
HWYSTR455's Avatar
Ah, original engine, understand why you don't want it in the rotation. Yeah, as I mentioned, and others too, it's not an optimum combo, but you should be fine with it. I'm a Crower fan, obvious from other posts, so I would lean towards the 60916. I would say though that you would be best off purchasing a new cam and lifters, but that's your call. And considering the type of build the engine is, I would stick with a hyd cam, save the roller money for another build.
Old 12-16-2009, 08:49 AM
Slick's Avatar
Slick Slick is offline
drevil1,
Given that you're trying to use what you have and minimize further out of pocket expenses right not, the best advice, already mentioned, may be to rebuild those 62 heads. Compression will be right on for the RAIV cam.
IF money permits, I'm sure you'd be pleased with the results of a port job on them by someone like SD Performance. But that may be above budget.
Best of luck,
Stuart
