When did Pontiac stop using the nylon tooth gears? Thanks -Jim
From various articles I've read on the subject.....it was mid-way through the 1971 model year....
Why should that matter at this point in time.
If you have a old motor that is still running you can check the condition of the chain by just pulling all the spark plugs and the distributor, than grab the balancer and move the crank back and forth some. You should see the distributor rotor follow right along if the chain is good. In fact if you spin the motor over thru one full rotation you can tell if the cam gear has a chipped nylon tooth by the rotor falling behind a good amout. If I recall right, it was thru mid 66 that the nylon gear was used.
I could have sworn that my 79 Firebird, with a 301, had nylon timing gears.
John ![]() "There are no stupid questions, but there are a LOT of inquisitive idiots!" |
![]() Quote:
no, it was later than that. I was riding in a '69 or '70 when the gear went on a trip from Yosemite to San Diego.
George
67 Lamnas has it right.
1971 was the last year.
Jim, I had a 70 with the nylon gear and a 73 without. So I tend to agree with the others re: 71.
"Objects in mirror are closer than they appear" ![]() |
Thanks guys. I have almost lost my Christmas spirit with this motor! Broke off 2 exhaust bolts flush and now it looks like I need to swap the chain. It is kinda funny. It all goes so well in my imagination-LOl. Merry Christmas to all! -Jim
One of my high school buddies 350 68 Tempest lunched after he shut it off at his girlfriend's house. Came back out to leave and all kinds of popping and wouldn't restrart. Better than the 6500 deal!
My 71 T-37 had one. Let go at 85,000 miles!
78 Grand Am,455,KRE D-Ports,Turbo 400 conti conv,3.42 Rear |
Skip, when mine let go not only was all the shredded nylon crap everywhere but I also had holes punched thru several pistons from valves. Carnage. Lesson learned, never again. My guess is the nylon teeth were an idea from a recent graduate engineer to keep down the noise from the chain. Other than the narrow bore spacing that was one of the worse ideas at Pontiac. -Jim
All GM engines except for the L6 used this nylon gear POS. Even Ford used them. I had a 70 390 that failed when a piece of the gear wedged into the oil pump shearing the oil pump drive shaft causing the loss of oil pressure on the highway. Ruined the block.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
The nylon gear in my 67 HO let go in early 1970 at 72,000 miles. The teeth remained in the pan until I pulled the engine in the mid 80's. I was lucky in that I was backing slowly out of my driveway when the engine just quit.
There's certain 'coincidences' that take place in life. I have a '72 Grand Ville convertible with the still original 455. The engine has 215,000 miles on it and has been my daily ride for nearly 8 years. 65,000 miles ago, I put a NOS timing set on it with (you guessed it) a nylon top gear. I was thinking that maybe I should change it, so 2 days ago, I bought a replacement set - OE style Cloyes (with steel gears), then I came across this post - I have a certain job to do on my car tomorrow.
![]() Quote:
I had a complete '69 Grand Prix Model J given to me because the teeth were stripped off of the nylon cam sprocket at 97K miles. Bent all the pushrods and maybe a few of the valves, the pistons were all fine and the bore had little to no ridge so I reused them. |
I changed a lot of the things and removed a lot of oil pans/ oil pumps at my uncles' Pontiac Dealership, years ago. It was amazing that some of them even had any oil pressure with the crap in the pick-up screen.
I remember when Bill Jenkin's used to swear by the things as dampening the harmonics in the valvetrain/ camshaft. Maybe Bill was being paid to ease the racer's minds that everything was ok with a new chain and Nylon toothed upper gear even with a big camshaft. Tom Vaught ps They would shell big time when a guy was using the clutch to slow the car down after a higher rate of speed, pretending to be a road racer. . The camshaft/valvetrain still had a lot of inertia and you suddenly slowed down the crank with the clutch, goodbye gear.
I was teaching auto tech in Clovis N.M. in 1972 when a fellow teacher had his timing gear and chain replaced. His Pontiac was a 68 Catalina with about 58,000 on it. When I saw what his gear looked like I immediatly replaced the gear on my 67 Cat 325 hp 400. My gear and chain were pristeen. They looked like they just came from the factory. Funny how stuff works. I changed it any way. The local pontiac Guru told me to use a Tempest 4 cylinder gear and chain,which I did.
Back in the 1980's I helped a guy out in my spare time who swore by the Speed Pro wide link plate timing sets with the nylon top gear. He ran a small automotive repair business, and used them successfully in high Big Block Chevy engines. He had two cars that raced nearly every weekend out of his shop. One was a 67 Camaro powered by a 396, the other was on old Pro Stock chassis with a 454 in it. The Camaro ran high 11's, the Pro Stock car high 8's to low 9's depending on which engine was in it at the time.
In all the time that I knew him, they never once had any failures with those timing chains/gears. I remember he'd pull the engines and freshen them up on occassion, and we'd inpect the top gear and put it right back in service. Even when I built engines for my own cars, I'd chicken out and use the wide link plate sets with the iron top sprockets. Never had the first trouble with one, and I'm using one in my current 455 engine. I like the design and strength of the link plate sets, even though they are somewhat of a PITA to degree the cam having to use offset cam/crank keys......Cliff
Well fellas I got lucky. Today I pulled the fuel pump and peered in thru the hole, she has steel teeth! This is a 1970 455/370HP/XF, the guy that sold the car to me was the 2nd owner and he purchased it with about 40,000. So, either it originally came with a steel gear or the 1st owner had already changed it. I did go back and double check the VIN` with the block and it is number matching. So who knows. I would say to all that if you are not sure what you have then pull the fuel pump and check. Shredded nylon teeth are a terrible experience. Thanks to all. -Jim
