Old 01-20-2010, 11:02 PM
ericwy's Avatar
ericwy ericwy is offline
Default Hi flo metalic vs normal ceramic catalytic converter?
Greetings All,
Searched the exhaust forums but did not find an answer.
Whats the diff between the "hi-flo" Metallic substrate catalytic converters and the
standard ceramic substrate?
I have a Pypes 2.5" X-pipe system I will be installing soon. I am putting dual cats on it
and I just want to know if it worth the extra expense to use the hi-flo metallic substrate.
The old system is a 2.25" H-pipe with dual cermic substrate cats.
Are hi flo cats any use on a street only car?
1977 TA 400 9.5:1 CR 351hp 414LbFt, #13 Heads + 1.52 Roller rockers, 1968 Pontiac 400 intake, Holley 4165 650 DP #7054
Howards Hyd .447/.467 IN:288 EX:298 214/224@.050, MSD6A + MSD timing control + H2o/Meth
1-5/8" headers, Magnaflow 200CPI Cats + 2.5" Pypes X, Dynomax STs, TH-700R4 2200 stall, 3.42 Eaton 10-bolt, PS/PB/PW/PL/AC/Cruise
13.84@100.14mph 2.18 60' on P255-60-R15 radials, pump gas, mpg : 21.5 hwy 15.2 city
Old 01-21-2010, 03:51 PM
ericwy's Avatar
Any opinions on Pypes CVM11K 2½" Highflo Mini-Cat w/ Metallic substrate Kit ?
Any thoughts appreciated.....
