Old 01-22-2010, 04:12 PM
lkt1954's Avatar
lkt1954 lkt1954 is offline
Default Vent Tube Question
During the restoration of my 66 GTO the radiator shop the cleaned my gas tank welded up the vent tube hole and in the rush to finish I just put the vent tube in place in the trunk and let it unhooked. Every time I take the gas cap off there is pressure. I think I want to hook up the vent tube for pressure relief and correctness.
My initial thought is take a very damp rag and stuff it down the filler neck enough to seal it off and then drill a hole for the line. I am thinking a rag that wet should absorb any vapors for a short period of time. I think I can do this without dropping the tank. Any thoughts here or just get a vented cap or drop & drain the tank then do this?
Larry
Get in-Sit Down- Shut Up - Hold On
Old 01-22-2010, 04:22 PM
Rugratman's Avatar
Rugratman Rugratman is offline
A vented cap will spill everywhere, when you nail it full, it will come out.
Did they just fill in the end of the vent tube on the neck?
The reason I ask, on my 67, the vent tube on the filler neck is kinda long. I could see just drilling out the weld, or cutting a 1/2 inch off it. Still plenty of room, for a rubber hose to slip on.
........I'm just learning as I go.......
Old 01-22-2010, 04:27 PM
lkt1954's Avatar
Rugratman- the patched the hole, the tube on the filler neck was gone and I assumed it was just a hole in the neck didn't realize till reassembly what it was for.
Old 01-22-2010, 05:01 PM
Rugratman's Avatar
So, if you drill out the spot, then what?
To be done in the right spot, I would think the tank would have to be dropped. I doubt you can get a drill in the right spot for the angle .
In case you did not know, the neck had a 1.5 - 2 inch tube for the vent, that was then run up and bent over then came back down.
The originals were rubber then metal, I believe.
I just used a piece of braided steel AN line and did the same. But the vent tube is kinda important, are you going to tap it?
Old 01-22-2010, 05:07 PM
Rugratman's Avatar
Pics, hope they help.
You might be able to lower it a bit and use a really long bit. Doubt it though.
ID:	194806   Click image for larger version
ID:	194807   Click image for larger version
Old 01-22-2010, 05:18 PM
lkt1954's Avatar
Rugratman- I have the correct vent tube and grommet in the trunk now, it's just not hooked into the tank. I though of drilling a hole then using jb weld to mount a short nipple like in your picture to the tank then connect the vent tube to that.
Larry
Old 01-22-2010, 06:07 PM
Rugratman's Avatar
That nipple is pretty skinny, even a small piece of brake line might work....good luck, and dont blow yourself up...LOL
