I am working on my son's 69 Firebird. I need to know where the vacuum advance hooks up, and where the modulator for the transmission hooks up. I also have two vacuum lines that are capped in the back of the carb where the brake booster hooks up. Any idea what those are for?? Pictures would also be nice if possible. Thanks. Aaron
As a general rule, trans modulators need a manifold vacuum source that has vacuum all the time. The distributor advance needs a ported source, where it only sees vacuum when the throttle blades are open above the idle speed.
Pics of your setup and type of carb would help answer your questions.
If it ain't broke, fix it 'till it is |
It has the stock intake and q-jet on it. I will post pictures later.
Here are the pictures of the carb. The vacuum modulator hose for the trans is on the lower left in the first picture. What is the carb fitting on the back for?? Thanks. Aaron
Not sure if you have THM400 or 350. Modulator valve vacuum tube for the THM400 should run to the vacuum port on the front of the carb on the passenger side that you have plugged. The distributer vacuum line is run to the small vacuum port on the lower front driver's side port. Looks like you are running the brake booster hose to the correct vacuum fitting on the back of the carb.
Tom
1969 Firebird 400 Convertible "We have got but one life here. It pays, no matter what comes after it, to try and do things, to accomplish things in this life and not merely to have a soft and pleasant time." - Theodore Roosevelt "Light travels faster than sound. That is why some people appear to be bright until you hear them speak." - A father's words of wisdom to his children |
