Old 02-12-2010, 05:55 PM
Pontiacshack Pontiacshack is offline
Default 65 421 tri power engine
This is a 356 horse 421 tri-power engine that runs great. The tri power was gone when I got it, but I do have a complete 65 tri power that will go with it. I put a manifold and carb on the engine, changed oil and it fired right up. I believe it to be 123,000 miles, compression is great, no smoke when it's running. This came out of a 65 catalina 2+2 4spd car. The engine code is WH and it does have the # 77 heads on it. Complete w/the manual steering bracketry, pulleys and alternator. The 65 tri power will need to be rebuilt, been sitting for some time now in my house. $3500.00 for everything.
Thanks,
Stef
Old 02-12-2010, 06:24 PM
65WJ's Avatar
65WJ 65WJ is offline
what happend to the car?
fyi WG is the 338 4bl engine. WH is 356 tripower.
Nice piece you have.
patrick
Old 02-12-2010, 06:56 PM
Ya, my bad, it's a WH, my buddy has a WG. The car was real real rusty, it's up north being used as a parts car. I could probably get you in contact with the new owner if you are interested.
Stef
Old 02-12-2010, 08:59 PM
bdk1976 bdk1976 is online now
If you (or the eventual buyer) need a rough '65 2+2 project car to put that 421 into to complete the package, I have one available.
Old 02-15-2010, 06:46 PM
cheesepocket's Avatar
cheesepocket cheesepocket is offline
Do you have the date code for the block, by the distributor hole?
1965 2+2 'Vert 421/356 3X2 4-speed
1965 2+2 hardtop autotragic
1972 Datsun 570Z
