Old 02-16-2010, 12:31 AM
carmak's Avatar
carmak carmak is offline
Default 65-70 3.42 posi gears and carrier $450
I am selling a 3.42 posi out of a 66 Bonneville. I have the ring gear bolted to the carrier, the pinion gear and the side shims.
I pulled the gears out of the case and cleaned the grease off this weekend. The car the gears came out of had an interior fire and then sat for about 10 years
I am asking $450 plus shipping
Carmak
[email protected]
ID:	197444   Click image for larger version
ID:	197445   Click image for larger version
ID:	197446   Click image for larger version
ID:	197447   Click image for larger version
Old 02-16-2010, 12:33 AM
carmak's Avatar
More pics
ID:	197449   Click image for larger version
ID:	197450   Click image for larger version
ID:	197451   Click image for larger version
ID:	197452   Click image for larger version
Old 02-16-2010, 12:34 AM
carmak's Avatar
last pics
ID:	197454   Click image for larger version
Old 02-16-2010, 10:29 AM
carmak's Avatar
I forgot to explain the light rust on the spider gears the other spots around the carrier. Last fall I pulled the cover and cleaned out the inside of the housing with gas to get pictures a potential buyer. I greased the ring and pinion but didn't think to grease the spiders or the rest of the carrier. I put the housing cover back on but I didn't seal it. Some condensation got in and resulted in the light rust you can see in the pictures.
Carmak
Old 02-16-2010, 01:19 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Is this a 10 bolt or a 12 bolt Chevy or POB?
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 02-16-2010, 01:46 PM
carmak's Avatar
It's the 65-70 B-body 10 bolt. It is the stock rear end out of a 66 421 Bonneville.
Are there any other part numbers or casting numbers I should get pictures of?
Old 02-16-2010, 10:16 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
Actually, it's a 12 bolt rear with a 10 bolt cover. The 65-70 3.42 posi is very hard to find these days. Do yyou still have the housing?
[SIGPIC][/SIGPIC
Old 02-17-2010, 12:23 PM
carmak's Avatar
I do still have the housing.
Carmak
Old 02-18-2010, 05:33 PM
carmak's Avatar
I have a sale pending. I will relist if it falls through.
Carmak
