Old 02-18-2010, 12:44 AM
steves1967 steves1967 is offline
Default Camaro/Firebird fenders
I found a good deal on a set of Camaro fenders for my 67 Firebird. Are than any major differences that would prevent them from bolting up? I have re-pop fenders now and I'm really not happy with the fit.
Thanks!
The Following User Says Thank You to steves1967 For This Useful Post:
Old 02-18-2010, 07:27 AM
boater bill's Avatar
boater bill boater bill is offline
You will need to drill the holes for the Firebird and Bird emblems. The 68 Camaro has the side marker light in the fender and would need to be filled. Other than that, I think it will work. Maybe someone else with more experience will contribute.
The Following User Says Thank You to boater bill For This Useful Post:
Old 02-18-2010, 08:46 AM
Ron Landis's Avatar
Wink Actually...
they are virtually the same for the same year car. We have NOS Camaro fenders that came with the '67 Firebird. At least as far as I can tell...they'll work fine.
The Following User Says Thank You to Ron Landis For This Useful Post:
Old 02-18-2010, 09:32 AM
HO 67 BIRD's Avatar
HO 67 BIRD HO 67 BIRD is offline
also the fender extensions are different, the camaro has bumper bracket provisions and the firebird being straight across to where it bolts to the lower portion of the fender.
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER
2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER
The Following User Says Thank You to HO 67 BIRD For This Useful Post:
Old 02-18-2010, 12:15 PM
DanC's Avatar
DanC DanC is offline
Thumbs up
The fenders are the same. When I bought my NOS ones 17 years ago from Pontiac they were not drilled for emblems or had the Camaro light cut outs. When I inquired about the lack of emblem holes I was told the Camaro and Firebirds used the same fender.
The Camaro uses the header panel in front of the hood which is where the fender to core support gussets mount on the Firebird. And the lower fender extensions are separate so the two 'F' bodies could share the same fender for two years!
If you are looking at used original Camaro fenders then as Boater Bill said, you'll have to fill in the side marker opening.
DanC
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
Old 02-18-2010, 09:28 PM
Thanks guys!
Old 02-18-2010, 10:44 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
If memory serves me right had to modify the front of the fender above the signal light. Was a fold for the Camaro signal light that had to come down, very minor work
The Following User Says Thank You to PLAY400 For This Useful Post:
Old 02-18-2010, 11:55 PM
A Schab A Schab is offline
The area that PLAY400 is talking about is for the Camoro bumper mounting bracket,just work the bottom of the fender flat to match the lower extention and it will work.
The Following User Says Thank You to A Schab For This Useful Post:
Old 02-19-2010, 07:27 AM
chrisp chrisp is offline
Standard 67 camaro's will need mod. in the headlight area , rally sport is the correct fit , as the rs had hideaway headlights and the mounting for them is sunken in farther than a standard camaro . Only rs fenders will fit with no mod .
The Following User Says Thank You to chrisp For This Useful Post:
