Old 02-21-2010, 10:08 PM
acgwinn acgwinn is offline
Default rear end ?
I'm looking at a rear out of a 69 Camaro. I want to use it for my 69 bird. My question is this. The camaro rear has a 2:73 gears and is a posi unit. I want to put either a set of 3:23 or 3:55 gears in it. Is this possible, or do i have to change anything? Do i just need to by the gears and installation kit? Thanks for any info. Damian.
Old 02-22-2010, 03:32 AM
A.J.'s Avatar
A.J. A.J. is offline
isn't the Camero rear 1" narrower? It will fit but it might effect how your rear wheels sits....
Reef turqoise -66 GTO
Firebird Convertible -68 R.I.P.
-73 LeMans 350/350 Barnfind
Old 02-22-2010, 07:32 AM
limejudge69's Avatar
I believe you would need the 3 series carrier to go numerically higher than 3.08
PY member 'monzaz' is a great source for info and parts. Also keep in mind that the Chevy 8.2 is different than the Buick/Olds/Pontiac 8.2. You could use a ring gear spacer, but they have a reputation as being dangerous on a street car.
Old 03-09-2010, 01:57 PM
zman1969's Avatar
zman1969 zman1969 is offline
If going to do swap, use a 72-78 nova 8.5" - alot cheaper than the chevy 8.2 and parts are alot more plentiful and its 1" narrower as is the early camaro 8.2 - and lots stronger!
Old 03-12-2010, 03:16 PM
cutlas cutlas is offline
I used a nova rear end in my 67 Bird.
Here is a good link for figuring out what one you want.
http://www.novaresource.org/axle.htm
Joe.
Old 03-14-2010, 08:21 AM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
Better then the Nova rear, look for the same in any BOP car, and you'll get better axles, and bolt in rather then the C clips. The 10 8.5" corporate was also made for the BOP cars, and is also like the 8.2" with the bolt in axles. Parts from all the 8,5" will swap from one to another as far as gears go. But the better axles were in the BOP cars. Same as with the 8.2" Not sure if spline count is better in BOP 8.5"
Build it fast, build it right, hold On TIGHT !!!
Old 03-14-2010, 08:15 PM
rohrt rohrt is offline
RR67GTO
No such rear exist that will bolt right in the F-body, at least non that I have found. All the 8.5 from the Ventura, Olds Omega & Buick Apollo from capatible years were are all C-clip.
Old 03-21-2010, 04:59 PM
69 redbird's Avatar
69 redbird 69 redbird is offline
Default rear
I put a 3:35 posi rear in mine last year. And i wish i would have gone with the 3:55. I still have a hard time spinning the tires....
Old 03-21-2010, 07:11 PM
amcmike's Avatar
amcmike amcmike is offline
Then you either have a heck of a set of sticky tires, or something is seriously wrong with your setup even for a 350. Note that a 3.36 ratio 2004r is equivalent to a TH350 with a 3.67 rear gear... not a bad combination.
Back to topic.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 03-22-2010, 07:15 AM
Ron67's Avatar
Ron67 Ron67 is offline
You would need a spacer plate to run 3.55 on that carrier I believe is only good up to 3.23 gears with out the plate. Here are the ones summit has http://www.summitracing.com/search/P...word=ring+gear
Old 03-22-2010, 09:19 AM
Bjorn's Avatar
Bjorn Bjorn is offline
yes it is...
FireBjorn
http://FirstGenFirebird.org/show/closeup.mv?CarID=221
breathe and enjoy it , life is temporary
69 Firebird convertible
71 Triumph TR6
