1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 03-13-2010, 05:25 PM
kenaparker kenaparker is offline
Default 1992 trans am convertible top help
does anyone have the manual on how to operate? My top is down and for the life of me I can't remember how to get it up. It has the hard cover which has a release behind the drivers seat but not sure if I missing something as it won't release.
Old 04-20-2010, 01:14 AM
Formulabruce's Avatar
After you pull the CABLE release , you press down on the toneau and slide the electric swich to unlock it. The top will release enough to grab it and manually raise.
" Long may we DRIVE !"
Old 04-20-2010, 09:10 PM
Default thank you
The switch is electric! I will check the fuse and hopefully that will do the trick.
