Prev Previous Post   Next Post Next
Old 03-19-2010, 10:33 AM
69 redbird's Avatar
69 redbird 69 redbird is offline
Default need help plz
My 69 FB has the OE 350 block with 73 heads from a 350 or 400? Anyway i changed the intake gasket and thats when i found out? because the middle ports on both sides are leaking.... I found some threads that said it can be fixed by useing the gasket from the 73 model and or using a block off plate? My question is? if I'm blocking those middle ports? I'm probably partially blocking some others too? i guess? I'm i losing power by doing this? This is a street car, a cruiser only. I don't race it, but do like to burn the tires from time to time
Or should i just invest in the right intake? and if i do, which one?
Please help i want to get my car on the rode ASAP....
