Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Closed Thread
Old 03-30-2010, 10:21 AM
ry57pont's Avatar
ry57pont ry57pont is offline
Default power steering, Lares coperation.-beware
I tried to return a rebuilt power steering box out of my 70 gto this weekend, only had 300miles on it, still looked new, but did not function properly. I bought local to support local buisness. this particular company (Lares Coperation) does a lot on ebay as well. Even though is was still "like new" with the Lares coperation inspection sticker still on it, they told me to take a hike witout a recipt. his exact quote "you could have just found that box in the junkyard" really? lot of 70gtos in the junkyard? yes i guess the burden of proof was on me, but jesus- cant any one use some common sense. buyer beware if you buy a box from them. - Ryan
1970 gto (4spd) 462 500 hp
[email protected] / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 03-30-2010, 11:57 PM
wheelspin's Avatar
Default Bad experience w/ Lares rebuilts........
I purchased a rebuilt p/s pump and gearbox from one of the Pontiac suppliers for my 68 GP and experienced problems w/ both units. The supplier refunded the price of both units, but I am out the labor to change them out. The cores on both rebuilt parts were so badly worn that they were not even suitable for rebuilding. I ended up rebuilding my original steering box and purchasing a new "blue-printed" pump from Summit after trying THREE other pumps from local auto parts store, none of which made more than 400psi instead of the spec 1500psi.
With only well-worn used cores available for rebuilding, I advise members to disassemble rebuilt pumps & steering to check them for out-of-spec wear before installation.
Les
Les Iden
Closed Thread
Smilies are Off
