Old 04-07-2010, 08:07 PM
GTONUT57 GTONUT57 is offline
Send a message via AIM to GTONUT57 Send a message via Skype™ to GTONUT57
Default Correct bulb for map light
Looking for correct bulb number for the map light above the radio on 68 CONVERTIBLE. The one I have now seems to be too hot for lens and it may melt if left on or door is ajar.
Old 04-08-2010, 12:17 PM
rlfonad's Avatar
rlfonad rlfonad is offline
Default My '68 Pontiac Owners manual ...
My '68 Pontiac Owners Manual lists a 550 bulb for the Courtesy lights.
I don't see any other called "map light" and it certainly wouldn't be a dome light.
I hope that's correct.
Old 04-09-2010, 10:03 AM
Steveski Steveski is offline
Sorry to say it is extremely hard to find. Don't know if one can be fabricated. I paid a premium price on Ebay a few years ago for a whole NOS map light assy mainly just for the bulb. I pray it never burns out! Good luck.
Old 04-09-2010, 10:54 AM
rlfonad's Avatar
Default PY or Ames ...
I don't know if our PY carries them, but I found Ames catalog calls for a #89 bulb for the underdash courtesy lamp.
They are only $1.00 each.
If you give either PY or Ames a call, they will tell you if it's the correct one.
Good luck ...
Old 04-09-2010, 01:42 PM
Old Goat 67's Avatar
If all you can find is a bulb that is too hot, add a resistor in series with the bulb socket to drop the current flow to it. Having a decade resister box as I do would be the easiest to determine value, maybe you know of a electronics repair shop that would have one you could borrow.
What bulb do you have now?
Charles
Old 04-09-2010, 02:35 PM
webfoot's Avatar
webfoot webfoot is offline
Just saw a bulb and new courtesy lamp end for $57.88, wife called me down for lunch and I didn't even think to tell her "just a minute..."
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 04-09-2010, 02:48 PM
Thanks for all the input. The above radio under dash pad map/courtesy light requires a wedge style bulb. It has wedge ends on both sides. The 89 is a bayonet style in other word it goes in to a socket and twist to lock. As Steveski mention they are hard to find but I am trying to find the number to possibly cross reference. I may have to do as Old Goat 67 mentioned, install a resistor and hope bulb does not burn out. Thanks again.
Old 04-11-2010, 12:28 PM
550 as rlfonad (double wedge) mentioned is the correct number and appears to be the same as a 68 caddy light. I went with a resistor to tone it down a bit to reducing any browning of the lense from the heat
Old 04-15-2010, 10:29 AM
rlfonad's Avatar
Question Just to follow up ...
Does anyone have a picture of the actual 550 bulb they could post?
I have a couple of old bulbs, but can't find any markings on them.
I would expect it to be shaped like a cylindrical fuse.
Sorry GTONUT57 for hi-jacking your thread, but you got me curious whether I have one of these bulbs.
Thanks, Ron
Old 04-16-2010, 12:50 AM
Default 550 Bulb pic for 68 map light
Attached is a pic of the bulb. Did a close up of number hope its readable #550. Plus through in an extra
ID:	203437   Click image for larger version
ID:	203438   Click image for larger version
Old 04-16-2010, 04:35 AM
Seeing what you are up against there, I believe I'd use an LED in there. No heat either.
Solder some short wire leads to it and attach to contact points. Try your local electronics parts supplier or Radio Shack.
Old 04-16-2010, 09:58 AM
rlfonad's Avatar
Default Not quite what I thought...
Thanks GTONUT57
I thought it would have metal ends similar to a cylindrical fuse.
I sure don't have one of these.
Ron
Old 04-28-2010, 11:50 AM
rlfonad's Avatar
Thumbs up A good replacement...
I just found a #562 bulb at an Auto Zone store that works great to replace the #550 discontinued bulb.
It is a 13.5V, 10W with a "U" shaped wire contact on both ends.
I used a needle-nose pliers to re-shape the ends to a more rounded "U" and bent the two ends back onto the bulb ears.
I put the bulb into a courtesy light, hooked up a battery and it looks very good.
There was another bulb that was similar, but was 12.8V, 13W (#561 I think). I went with the lesser wattage.
I would think any auto parts store would have them.
Ron
Old 05-18-2010, 08:16 PM
sdk3k's Avatar
sdk3k sdk3k is offline
Ron
The #562 bulb works great. Thanks for the tip!
