Old 04-10-2010, 05:13 AM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Default A/C Wiring help
Would much appreciate if someone could post some pics of the a/c harness in the engine bay, mainly want to know, what wire connects to the compressor and where they come from. I am missing this harness but I think I found it in a box of parts, but the connector to the compressor is missing a wire, if this is it.
Old 04-11-2010, 05:13 AM
Ozzmann's Avatar
Is one of the compressor wires a earth?
Where exactly does the wire to the alternator attach?
Old 04-12-2010, 07:07 PM
65WJ's Avatar
65WJ 65WJ is offline
I will go out and snap a couple pictures for you in a few. Hang in there.
patrick
Old 04-12-2010, 09:28 PM
Ozzmann's Avatar
Thanks Patrick.
Old 04-13-2010, 06:01 PM
65WJ's Avatar
Good morning in Aussie land. These are not the best but hopefully you can get an Idea of what goes where. The 30 amp fuse link comes off the engine harness on the intake side. The extension that plugs into the compressor comes off the harness on the ac side.
If you need more detail I will get it out in the sun and take better pics.
patrick
ID:	203190   Click image for larger version
ID:	203191   Click image for larger version
ID:	203192   Click image for larger version
Old 04-13-2010, 08:15 PM
Ozzmann's Avatar
Thanks Patrick, now is one of the wires from the compressor attach to a earth?
and where on the alternator does the 30 amp wire attach, with the main power wire?
Also mate I see in your pic of the compressor you have no rear brace bracket, is only the main bracket holding the compressor in place?
Do you not need the rear bracket?
Old 04-13-2010, 10:07 PM
65WJ's Avatar
Originally Posted by Ozzmann View Post
Thanks Patrick, now is one of the wires from the compressor attach to a earth? yes attaches to the back of the bracketand where on the alternator does the 30 amp wire attach, with the main power wire? Under the red cap
Also mate I see in your pic of the compressor you have no rear brace bracket, is only the main bracket holding the compressor in place? You do not need it
it gets in the way and muddies up the already busy engine compartmentI will get some better pics for you tomorrow.
patrick
Old 04-13-2010, 10:30 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
patrick
Hey Patrick, that was great of you to do! Nice pictures. Returning the favor, you can eliminate that coolant leak (if timing cover gasket) by loosening the intake bolts slightly and then pulling the intake close to the timing cover with the long bolt, then re-torquing the intake bolts.
Good luck!
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 04-13-2010, 11:26 PM
Ozzmann's Avatar
Patrick your a champion, thanks heaps mate, if your every over here I'll buy ya a beer.
Old 04-14-2010, 07:54 AM
65WJ's Avatar
yes I can. I had better do it quick before they slice and dice my wrist. Second surgery from wreck already had the left one done.
ps my brother did not tighten the long bolt before the intake bolts. lol
Good luck!
No Fosters that is nasty nasty nasty.
patrick
Old 04-14-2010, 06:16 PM
65WJ's Avatar
Default more wire harness pics
Here are some more and better pictures. The extension harness connects to the relay on the firewall. Part of goes to the compressor the othe half goes undernieth the air box.
Please ignore the coolant leak. lol
A couple for inspiration if needed.
patrick
ID:	203289   Click image for larger version
ID:	203290   Click image for larger version
ID:	203291   Click image for larger version
ID:	203292   Click image for larger version
Old 04-14-2010, 06:19 PM
65WJ's Avatar
Default a few more
just a couple more. If you find you need a certain angle let me know.
patrick
ID:	203294   Click image for larger version
ID:	203295   Click image for larger version
ID:	203296   Click image for larger version
ID:	203297   Click image for larger version
Old 04-17-2010, 07:11 AM
Ozzmann's Avatar
Those pics will be very helpful Patrick thanks, could I get one of the bottom pulley with the A/C belt, mine looks like the belt goes at the back, between the balancer and 2 grove pulley, is this correct.
Your goat looks good, love the tail.
Old 04-17-2010, 10:55 AM
65WJ's Avatar
There are 2 pullies. A single grove for the compressor. It is closest to the timing cover followed by a spacer then the 2 grove pully.
Ram Air Restorations makes a really nice billet set.
I will get some pics for you today.
14hr time difference? its 11am Saturday here.
patrick
Old 04-17-2010, 12:57 PM
Ollie's Avatar
Ollie Ollie is offline
Yes, Ozzmann, The AC pulley is the one closest to the engine.
Its ok to giggle and snicker, Dont laugh and point
Old 04-20-2010, 05:16 PM
65WJ's Avatar
Default ac pully pictures
Sorry for the delay. Here are the pictures of the ac pully.
Old 04-25-2010, 05:09 AM
Ozzmann's Avatar
mmm.... It seems I don't have that single grove pulley, another bit I 'll be chasing, thanks again Curt.
Old 10-04-2010, 09:15 PM
Ozzmann's Avatar
Well I'm back to this job of refitting my A/C as I now have all my brackets.
Can someone please post up a pic of the rear of compressor and where the short bracket attaches to the motor, I think I am missing a double ended stud off the head, just need a pic to confirm and show me where it sits.
Old 10-10-2010, 05:36 PM
65WJ's Avatar
ozz
I cannot help at the moment. I am on IR after 2 level fusion at C-5,6-6,7
Plus I took the engine out because of a knock.
Hopefully someone else can post a picture for you.
I may be able to scan the diagram of the ac assembly from the manual for you.
However thats in the basement. ughhh
patrick
Old 10-10-2010, 07:20 PM
68gtoMN's Avatar
Sir, I hope this helps (from Paul Zazarine/Chuck Robert's GTO Restoration Guide)
'70 LeMans Sport
Facebook Event
