Old 04-12-2010, 07:55 PM
hal101's Avatar
hal101 hal101 is offline
Default anybody use these
http://www.thefind.com/hardware/info-torque-angle-gauge
Old 04-12-2010, 08:02 PM
73FIREBIRD's Avatar
73FIREBIRD 73FIREBIRD is offline
Yes I have one from snap on. Use it on Crower rods as that is how they set the torque on their rods. I like it very much.
Old 04-12-2010, 08:03 PM
mechanickeith's Avatar
Have seen them before but have never used one. I just mark the head of the bolt & turn it!! 1 flat is 60*, 1.5 flats is 90* etc etc. I mark one corner of the bolt & if I am going say, 120 degrees more, I mark the block/part 2 corners to the right & turn the bolt till the marks line up. I have painted stripes on the side of my sockets. I put the socket stripe on the mark on the bolt & turn till it lines up with the mark on the block, head what ever.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 04-13-2010, 12:07 AM
screamingchief's Avatar
screamingchief screamingchief is offline
Yep,those are used alot on mondern engines using "torque to yeild" headbolts.
Any skilled line tech should be pretty familiar with them by this point in time.
Used those quite a bit when I was a tech @ the ford dealerships.
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 04-15-2010, 08:30 PM
quick66's Avatar
quick66 quick66 is offline
I'm a line tech by trade and see a lot of torque to yield bolts...like Bret said...head bolts..flywheel..some motor mount bolts as well...but I do like Keith says..the tool is nice but not necessary...Gene
'66 GTO 3600lbs w/driver, e-heads,474 N/A . best 60' 1.305...best 1/8th ...6.205 @ 110.14...best 1/4 9.794 @ 136.15 through mufflers on e-85
