Old 04-24-2010, 08:53 PM
MescaBug's Avatar
MescaBug MescaBug is offline
Default Everything quit while car is running?!? 72 GTO
Hey guys,
I have this weird problem.. 72 GTO, 400 engine, HEI ignition, console shift TH400. Tried to do a search but the seach engine is buggin on me.
My car has never done this before. I was driving, like 50MPH, when all of a sudden, everything quits. Engine stops, no power, no nothing. I was able to steer in a parking lot.
I had absolutely no power whatsoever. No GEN light, no starter, no radio. Completely dead. I waited about 15 minutes, ready to call a tow, I tried it and it started right away like if nothing had happened.
I drove for another 20 min, and blawwww. Same thing. Waited 5 minutes this time, and started right away again. It did this all afternoon!!! Randomly
I had the hot-start problem with the Firebird. After a while, it wouldn't start because the starter was too hot. But at least, I had power!
Battery seems to be fine, lots of cranking power.
What could that be? Ground problem? Ignition switch? Alternator? I'm lost. And desperate.
Dave
Old 04-24-2010, 09:23 PM
SD73's Avatar
SD73 SD73 is online now
I'd start with a ground problem. Check all the connection to and from the battery. I had a similar thing happen on my T/A. It turned out the neg wire from the battery to engine was bad. A continuity tester/volt meter should be a big help.
Old 04-24-2010, 09:27 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
Originally Posted by MescaBug View Post
Hey guys,
Dave
If it were me, I would do this first.....
Look at your positive battery cable and follow it all the way from the batt to the starter looking for chafing. Do the same with the smaller gauge engine harness wire that attaches to the starter, and the large diameter wire that connects to the main termin al on the back of the alternator......look for loose connections and chafing of the wire insulation
If nothing there, then look very closely at both of the bulkhead connectors where they attach to the fusepanel.....maybe the engine harness connector is loose with one or both clips broken....
"XE cam basher"
Old 04-24-2010, 09:54 PM
robz's Avatar
robz robz is offline
I agree with both posts above, Dave...how far are you from the west island?? Bring it over and I could check it out for ya...I'm in Bfld..
Robert
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
Old 04-24-2010, 11:15 PM
MescaBug's Avatar
Rob,
I'm in Plateau Mont-Royal. I'd be glad to look it over with you, problem is, will I make it? Lousy place to get stuck on H-way 20...
I'll PM you. We'll figure out something.
Old 04-25-2010, 01:51 AM
MescaBug's Avatar
Finally manage to do a search. Looks like you guys are pointing me to the right direction.
http://forums.maxperformanceinc.com/...d.php?t=438739
Old 05-03-2010, 10:26 AM
MescaBug's Avatar
I finally found the problem. I was doing the wiring for the wiper motor. I moved the alternator harness and blawww. Nothing. I knew where the problem was. Turn on the lights, move the harness a little, and lost everything again. That explains why I was losing all power. Vibrations.
Cables are badly damage, corrosion and dirt... The alternator wire is spliced with a bridge connector with 2 other cables; one black, one white. I think I was suppose to find a fusible link in that harness... Diner was ready so I had to leave it like this. I guess the red wire is coming from the starter, the black feeds the fuze box... The white one goes to the passenger side. Don't know what it feeds...
Old 05-04-2010, 07:32 AM
2002Z4CSS's Avatar
That Scotch Lock connector cannot hold up the the load. Solder the wires.
1971 Pontiac GT-37
Old 05-04-2010, 10:09 AM
MescaBug's Avatar
It held for a few years.. There is suppose to be a fusible link between those cables. I guess that's what I will do.
Old 05-04-2010, 06:43 PM
My442 My442 is offline
If it were my car, I would replace the engine harness and the front light harness IMMEDIATELY.
That is a fire waiting to happen.
Running without fusible links is very dangerous.
