Old 05-07-2010, 09:25 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Default Pontiac Engine Dyno- results and Video
(I posted in the street section earlier, but I plan on racing with this motor, after I get the car ready for it)
Pontiac 400 block, 6X-Heads, Eagle rotating assembly, Ross Flat-Tops, approx. 9.6 compression, Comp solid roller (custom grind), RPM intake.
A video of one of the runs (Not the best quality, but you can make out whats going on)
http://www.youtube.com/watch?v=c5_aaZ5RGCE
-Matt
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 05-07-2010, 09:57 AM
grandville455's Avatar
grandville455 grandville455 is offline
Your lucky u didnt melt something ! was pretty lean!.. the torque number is nice but it peaked and fell off immediately. Is this a stroker motor I take it? What is the cam specs etc, where installed
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 05-07-2010, 11:14 AM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
What Darby said X2. Scarry low oil pressure @ 5000+ RPM. I'd be checkin' the oil filter! - Bill
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 05-07-2010, 01:10 PM
Darby, yes it's a stroker=467 cid. The carb we ran was actually not mine- Ran a quickfuel, 650 i think. I had a vaccuum secondary carb that they thought wouldn't work correctly on the dyno. (thought probalby wouldn't open the secondary's correctly). Cam is solid roller, custom grind- 236/242 @ .050", net lift with 1.65 rockers is in .610-.630 range, 110 LSA, installed at 106 (or is supposed to be anyway.) I was really surprised at the torque figures it produced. it actualy touched 580.x in one run, but the printout was the best hp number.
Bill, ya looks like it dropped some... I'll cut into the filter before I get it in the car. This was an all new motor, broke in a tested in the same session.
Actually blew a head gasket the day before, but didn't do any damage to the rest of the engine.
Matt
70 GTO 400 4-speed
Old 05-07-2010, 02:15 PM
How many pulls did u make with that carb that lean? I would have stopped after the first pull, 650 is way to small for a 467...850 or bigger... Where was the timing at? The HP Peaked very early also. It did carry it out further,but man your torque fell like a rock. Was down over a 100 ft lbs at 5100... What size is your carb?
Darby
Old 05-07-2010, 02:37 PM
ry57pont's Avatar
ry57pont ry57pont is offline
FWIW, i we tried a 1000cfm (dyno shops carb) and it made no more power than my 830 chokeless on my 462. i would bet an 850 would be perfect (but again i am speaking form absolutely no expierence other than my own)
1970 gto (4spd) 462 500 hp
[email protected] / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 05-07-2010, 11:22 PM
Darby, This printout was of the 6th and final pull. I definately agree, 650 is not enough. I have a q-jet that Cliff rebuilt a few months ago, I'm pretty sure is 800 cfm. That's what I'm planning on running on the engine, at least for a while. If I feel it isn't performing at the track, I'll get a holley dp, probably 850. Total timing was at 32 degrees, seemed to be where it ran best.
I too felt like the HP peak was pretty early -earlier than I expected. I thought it would peak in the 5000-5300 range somewhere, but obviously that was not the case. (I thought, overall, the powerband was fairly good and broad, at least within the dyno pull's rpm range.)
Honestly, I thought it would be normal for torque to start tapering off like that after it got up into the rpm range... I guess i was wrong?
Matt
70 GTO 400 4-speed
Old 05-09-2010, 01:01 AM
Where do you guys think hp should have peaked in RPM range?
What numbers do you think it should make with better a/f ratio and larger carb?
Matt
70 GTO 400 4-speed
Old 05-09-2010, 12:57 PM
ta man ta man is offline
Dude I would not worry about your horsepower till you get a good carb and jetted properly.Like I said in the street section......Lean.
Old 05-09-2010, 03:17 PM
Unless heads were heavily ported that cam isnt going to peak power much higher rpm than where it did. Scary lean and scary oil pressure. Cliffs qjet should be a big improvement. You really dont need more than an 800-850 cfm carb with that combo anyway. Worry about your oil pressure and tune up. There is more power and tq to be found.
Old 05-11-2010, 11:27 PM
Excuse my ignorance, just trying to learn here...
Why is this oil pressure scary? Lowest I see on the video is 44 psi. Held over 50 psi throughout the pull, then on deceleration dropped briefly to 44 then back up.
Pull acceleration:
3300 rpm = 63 psi
4000 = 64 psi
4500 = 56 psi
5000 = 53-54 psi
5500 = 53 psi
On deceleration:
5500-5400 = 47 psi
5300 = 45 psi
5200 = 44.8 psi
5100 = 45 psi
5000 = 46 psi
4800 = 50 psi
4600 = 53 psi
4000 = 53 psi
3500 = 53 psi
3200 = 54 psi
educate me!
Matt
70 GTO 400 4-speed
Old 05-12-2010, 08:59 AM
60man's Avatar
60man 60man is offline
X3 on being LEAN & oil pressure.
A general rule of thumb is 10PSI per 1,000rpm. i.e. 5,000=50PSI. Was oil level correct?
I had trouble with lean situation my recent dyno session. Did you pull plugs ? Dyno sheet showed rich..plugs showed borderline LEAN. You can't play with timing much with a lean condition. when I got close on mixture we increased timing 2* (31 total) and found 18 more HP and moved HP band UP !!
I'm sure there is more in yours as well but watch OP & lean condition..
MY
ECM member.
MANDRA
Old 05-12-2010, 09:06 AM
Bill Boyle's Avatar
Bill Boyle Bill Boyle is offline
Matt--once you get the carb calibrated for your engine and tuned, to include timing, you'll make a bit more power throughout the engine range. Troy's comment about finding more power is true--tuning will do that. Be patient, take one step at a time.
