Old 05-10-2010, 02:11 PM
Hotrodizz Hotrodizz is offline
Default Steering shaft finish?
Ive searched the forum, and it appears the correct finish on the steering shaft is "natural". While stripping mine, it appears that it has a layer of black before hitting bare metal. Im not sure if this was an old rattle can job, or if 73's should have been black.
Any help??
TIA, Tom.
Old 05-10-2010, 02:36 PM
Brewster's Avatar
Brewster Brewster is offline
Black is the correct finish however most finishes wear off around 20k miles. Give or take depending on location, road conditions....
Old 05-10-2010, 02:42 PM
Thanks Brewster, would you say flat or semi?
Am I correct it seeing that the box should be natural cast?
Old 05-10-2010, 02:50 PM
Brewster's Avatar
The shaft is flat and natural is correct for the steering box.
Old 05-10-2010, 02:51 PM
Thanks again.
Old 05-10-2010, 03:20 PM
x-bird2 x-bird2 is offline
after you have it nicely repainted, splash a little brake fluid on it for a correct patina. I think that's why most of them look natural. ;~)
Old 05-10-2010, 03:24 PM
giles's Avatar
giles giles is offline
FWIW, The steering shaft from my '71 definitely had black paint and a green inspection mark near the rag joint flange.
