Old 05-20-2010, 05:12 PM
meyousikmann meyousikmann is offline
Default 78 TA Hard Starting When Warm
I've got a 78 TA that is very hard to start when it is warm. The battery is brand new. Whenever I park the car after driving some distance and try to come back and restart it within 30 minutes or so, it is very hard to start. It will crank very slowly once and then pause for several seconds then crank very slowly again. It has always seemed to get started after several very slow cranks, but I fear one of these times it will not restart or the battery will drain before it does.
Any clue on what this may be? Fuel pump? Vapor lock? ???
Thanks for any help.
Old 05-21-2010, 01:09 AM
2manyT/A'S's Avatar
Sounds to me like a timing issue? (like to much initial?)
Set it back to 10 or 12 degrees & see if that helps.
Couldn't hurt to check your block to battery ground & pos. terminal as well.
Old 05-24-2010, 10:03 AM
ta6point6's Avatar
sounds like heat soak is getting to the starter, the starter is very close to the exhaust. If you have headers it will make this problem worse. Try a heat shield or blanket to protect the starter from the heat
Old 05-24-2010, 05:49 PM
turbo's Avatar
turbo turbo is offline
That used to happen to my first car, a 79 Firebird. Check to see if you have a heat shield on your starter. Sounds exactly what used to happen to me back in High school.
In the birdcage:
1972 T/A, White with blue Deluxe interior
1973 T/A Brewster Green with Saddle Deluxe interior
1977 SE T/A, Black with Black Deluxe interior
1981 SE Turbo T/A, Black with Deluxe Tan velour interior. 19,000 original miles. Owned since 1984.
Old 05-25-2010, 02:58 PM
autobahn autobahn is offline
I also have a 78 TA and have had the same issue, got a starter shield from Jegs retarded the timing a couple and installed a aftermarket distributor, no more hard starts. ya the distributor was overkill, but it looks good
JIM
Old 05-31-2010, 12:07 AM
car guy car guy is offline
I bought a 79 TA new and it was that way all the time. I restored a 68 FB 400 with that problem and a heat shield for the starter solved the problem.
2015 Challenger SXT Plus
2013 Charger RT/RT Super Trac Pac
86 Grand Prix LE
79 Anniversary Trans Am
Old 05-31-2010, 07:33 PM
tqvhp's Avatar
tqvhp tqvhp is offline
I ended up going with gear reduction starters on both my birds.They work great,less weight and less amperage to start.
Old 06-03-2010, 07:56 AM
Wow, heat shield for starter. Never would have thought of that. I am going to try it out. Thanks for all the replies.
Old 06-03-2010, 11:06 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
Check the shape and routing of your wiring to the starter as well. 30 year old baked wires can cause hot start problems as well.
Old 06-03-2010, 11:18 AM
Most I've seen had a heat shield over the solenoid from the factory. It was suppose to help with hot 'no' start situations.
The hotter the windings in the solenoid and starter get, the less current flows through it. Just the nature of the beast when dealing with copper. Same thing holds true for battery cables.
Batteries also lose power when they get too hot. About the same as severe cold.
Always make sure cable connections are clean and tight, battery, starter, and block.
Hot engines are harder to turnover also, where cold engines usually spin easy. So don't rule out starter getting weak. Worn bushings and brushes make the starter weaker.
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 06-04-2010, 07:46 AM
2002Z4CSS's Avatar
Do a voltage drop on thew negative and positive cable when the engine is hot. May need a new cable due to high resistance.
1971 Pontiac GT-37
Old 06-26-2010, 04:17 PM
ve3wireless ve3wireless is offline
Default Hot Engine = Hard Starts
I had an eerily similar condition to yours here with my '78 T/A, back some 18 years ago, or so...
Finally I got underneath the car, & to my surprise, found that one of the wires hooked up to the starter was loose! In fact, LESS than finger-tight...
I simply cleaned everything up down there, applied new lock "star" washers on all the appropriate electrical connections, & that was the end of my issues...
I'll wager you have something similar there, i.e. just a bad connection. There's no heat shield on my car, & it starts just fine in our 90F Ontario Julys here now, hot or cold.
Eddy
Ontario, CANADA
Old 06-30-2010, 10:59 AM
77 TRASHCAN's Avatar
Loose cables/wires are nice to find BEFORE you go out and spend money...LOL
I was helping a friend w/ his 72, the starter bolts were very loose, AND the cable was loose...., for some reason, the thing had been still starting good...we were looking to replace the positive cable, because the battery end was goofed up, go figure....
Before you install the shield, make sure your starter is good, most parts stores can test them, beware of what you buy, though, I would much rather repair an original starter.
Shut it off
Shut it off
