Old 05-30-2010, 01:35 PM
FEMA FEMA is offline
Default 59 Water Pump suppliers
What's the recommened place to buy a water pump for a 59 - there are none listed on this sites store - also, what else should we replace while doing this job?
PS - It's been a while I know, but my son has had the car in Denver for his school year and driving it with no major problems...I think we are lucky the water pump didn't go earlier!
I have lot's of pictures to post that I promised a long time ago about our interior restoration thus far
Old 05-30-2010, 02:33 PM
stevep's Avatar
stevep stevep is offline
Just check the hoses and the condition of the coolant. That pump fits 55-early 63.
Napa should be able to get you a pump.
Old 05-30-2010, 02:56 PM
60man's Avatar
60man 60man is offline
Yep....and some of the NAPA lines carry a lifetime warranty !
I am sure they will have to order it for you....couple of days at most...usually.
ECM member.
MANDRA
Old 05-30-2010, 03:12 PM
Great, thanks guys! I had the pressure pump on it last night which is how I discovered the leaks - some hoses slightly and a small radiator leak just now seen. With all the crud on the front I can not see the water pump weep hole but since it is not holding pressure after tightening the hoses I am assuming the water pump seal is bad too - and after 50 years needs replacement
With the radiator do you guys recommend new of just repair? I'm also thinking a fan shroud would help so I'll look for that as well.
Old 05-30-2010, 05:26 PM
poison heart's Avatar
poison heart poison heart is offline
Send a message via AIM to poison heart
NAPA can also have it rebuilt if they cannot find you one. They rebuilt the one for my old Buick for $70 but it took them 2 months
Robert Lewis
1959 Star Chief 4 Dr HT dual quad 389 4 speed
1962 Pontiac Plain Jane Catalina
http://pontiac-59.com/
Old 05-30-2010, 09:33 PM
59safaricat 59safaricat is offline
If you're getting the pump from Napa, make sure you get one that rotates in the correct direction. If my memory serves me correctly, there are pumps available that rotate both clockwise and counter-clockwise. I've been wondering what models the counter clockwise pumps fit.
Old 05-30-2010, 09:51 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Either pump will work since they still rotate the same direction. But the reverse cooling 55-59 engines should have the cast impeller clockwise Napa #58594. 60-63 with the stamped ccw impeller #58298.
I was at autozone the other day and priced out pumps there as well for my 60 cover.
The kid behind the counter kept punching up the same 8 bolt water pump and after about the 5th time of me telling him no, he finally found the 4 bolt water pumps on his computer. They listed the cw and ccw pumps.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 05-31-2010, 09:22 AM
Bill Hanlon's Avatar
There is no such thing as CW and CCW Pontiac water pumps. Yes, the impeller looks different in some designs. And yes, the stamped impeller looks different (some folks say backwards) than the cast impeller. But they are all built to turn the same direction and provide coolant flow in the same direction.
Instead of continuing my rant, I'll point you to my previous rant on this subject:
http://forums.maxperformanceinc.com/...d.php?t=593938
which also includes part numbers from NAPA if you follow the thread far enough.
Old 06-01-2010, 09:56 AM
Excellent, I'll check with NAPA and report back as we proceed.
Old 06-02-2010, 02:44 PM
After looking at the old threads I'm still not sure I understand why there are different offerings and the CW, CCW argument but regardless, NAPA has them and based on what I read here 58594 is the the PN you guys are saying fits.
Both CPR and Ames also carry them cheaper than NAPA though no lifetime warranty.
A local machine shop friend of mine said they used to sell kits to rebuild them your self, or through the local machine shop - anyone try this?
Old 06-02-2010, 05:20 PM
PRC PRC is offline
They are also available through Rock Auto. That's where I got mine.
Old 06-02-2010, 07:13 PM
One more source, and this is interesting - CARDONE manufacturing sells thorugh many channels including auto parts stores and it's the exact same PN #58594 as NAPA. But here's the kicker, you can buy it through Summitt Racing for $30 or NAPA for $120
Anyone know if I am wrong in assuming these are the same part?
This is a good fact to confirm for all of us.
OK, so I see Cardone was already mentioned in past threads to confirm they rebuild for NAPA - so why should NAPA charge such a premium over Summitt? That makes me want to get away from NAPA!!!
Old 06-02-2010, 09:08 PM
Why is your Napa price so high? the last one I bought for my 287 5 years ago was in the $30 range.
6.27@107
9.97@131
Old 06-02-2010, 11:13 PM
Bill - I don't know but I'll double check tomorrow to be sure they got the right price.
As I look at the car it looks like more than just the round piece around the bolts will come off when I pull it - I've cleaned off lot's of the dirt and grease and I'll assume that's what's covering the seams between the pump and the engine for now, such that what I've seen in the pictures of the new pump are accurate.
Also, how do I remove the pulley?
Old 06-03-2010, 01:56 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
The pump is bolted to the timing cover, not to the "engine".
I paid NAPA about $50 for the 58594 pump.
If you've got the fan bolts out and the fan off, simply pull the pulley off.
Old 06-03-2010, 04:50 PM
Jack / all;
I double checked NAPA and it's $120.00 PLUS shipping for the cast impeller CW rotation, 58594 and $47.00 for stamped steel, which they also refer to as the CCW rotation unit.
So, I ordered from Summitt which gets them from Cardone who say this will be the cast unit for $29.00! Even if it's stamped steel still less than NAPA so go figure.
Old 06-04-2010, 04:11 PM
60man's Avatar
I might check for kicks & giggles on this. I worked for NAPA for years. Cardone was one of their suppliers. They sold several different levels of quality ...in all lines. Just because a part carries the same number doesn't meant it's made by the same MFG , it's a standard list number (most of the time)......I know the "lifetime" pumps I mentioned were NEW...not reman..and not Cardone...that I remember, maybe you can't get new ones anymore for our cars. What is Summits warranty?? With NAPA you generally just take back to store(with reciept) if a problem pops up...just like SEARS ..
That is a BIG difference in price !!??
See what I can find out...
ECM member.
MANDRA
Old 06-07-2010, 09:17 AM
Default If you are worried about "backwards" water pumps ...
... you should pounce on these.
http://cgi.ebay.com/ebaymotors/NORS-...item588819b74e
Old 06-08-2010, 02:37 AM
$19.50 is a great price for NORS. I wonder if water pump seals suffer from long-term (50 years or so) storage?
Old 06-09-2010, 02:43 AM
So much for that good deal. They refused to sell to me using a credit card on a phone call- insisted on PayPal, which I refuse to use.
