Old 06-01-2010, 10:06 AM
Hotrodizz Hotrodizz is offline
Default Auto Shift Plate
My original is broken. I thought I saw original GM is available as well as a repro. I gave my dealer the part number off the back 478570 and he says it is "not a good number". Anyone have a superseded number?
Old 06-01-2010, 10:39 AM
Held for Ransom's Avatar
The PN was 478573, which is probably no longer available. The repro unit is, I believe, made by OER.
Old 06-01-2010, 01:13 PM
Discontinued....some vendors still show GM or REPRO available, hopefully they have stock.
Old 06-01-2010, 03:02 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Here's a possibility
http://cgi.ebay.com/ebaymotors/NOS-7...Q5fAccessories
Old 06-01-2010, 03:05 PM
Thanks TA. I found another GM on Ebay this morning, did the BIN. I already had the OER repro and the font is different than the original. WHen I get the Gm piece, I will post pics side by side. The OER is very nice otherwise.
Old 06-01-2010, 06:51 PM
Norwood's Avatar
Norwood Norwood is offline
I will never understand these guys. They go to all the cost to tool up parts and then screw up the font...
Old 06-01-2010, 08:46 PM
Formulabruce's Avatar
Bla, cant expect the Chineese to get the english right can you???
" Long may we DRIVE !"
Old 06-01-2010, 09:58 PM
Do you mean other than the PRNDSL vs. PRND21?
Old 06-02-2010, 09:37 AM
They have the same PRNDSL, but the fonts are wrong on the OER. At least compared to the one that came out of my car, which has GM#478570 on the back.
Let me see if I can get a picture with my cell...
Old 06-02-2010, 09:51 AM
Old 06-02-2010, 10:23 AM
The D definately looks different.
Old 06-02-2010, 10:34 AM
robz's Avatar
robz robz is offline
and the S and N...That's terrible! Wonder who does their QA????
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
Old 06-07-2010, 02:55 PM
Ok, received the GM part today. It appears OER used this latest revision for their repro based on how close the font is.
Left to right....Original, OER, GM Replacement
Left to right...GM replacement, OER, Original
Came new in GM Box
OK, so the font on the new GM is clearly different than the original. I guess I should disassemble the original, and see if I can save the lens with the lettering and transfer it over to the new GM part.
Old 06-07-2010, 03:20 PM
giles's Avatar
giles giles is offline
I believe that GM changed the letters from "PRNDSL" to "PRND21" sometime in the late 70s. The part number 478569 has carried both styles over the years depending on when the part was actually made. Maybe someone more experienced with the late 70s cars can chime in as to when the letters were changed in production.
Old 06-07-2010, 05:24 PM
I wonder where I got the 478573 number from???
Old 06-07-2010, 06:32 PM
Transamric's Avatar
Most likely, that new GM part is the OER repro. GM is selling lots of parts in the current style packaging, as GM "NOS", when in reality, those are nothing more than repro parts in GM packaging.
Old 06-07-2010, 06:48 PM
While your statemeny may be true in general, I can tell you the OER and new GM are not the same.
Old 06-10-2010, 03:23 PM
Bought a repro "thin" shift indicator lense, and it is almost dead on for my original. Now just have to remove the annoying push clips from the plastic studs and swap the lense out on the new GM.
pic is:Original....repro lense....NOS GM shift plate/lense
