Old 06-03-2010, 10:01 PM
1978 T/A's Avatar
1978 T/A 1978 T/A is offline
Default What's This?
I know where is came from, but I have no idea what it's purpose is or even if it needs to be there. In tearing apart the engine I noticed this 'support' on the cylinder heads that covered the rocker arms. I noticed the left side had a crack in it. So I guess that means I need to replace it? But I don't even know if it is required for the rocker arms or what it is called lol.
Please help!
Old 06-03-2010, 10:16 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Oil dripper, no need to be to worried on the crack.
Leo
Old 06-10-2010, 10:04 PM
1978 T/A's Avatar
Glad I don't have to replace. Is this part critical and will it clear roller rockers?
Old 06-11-2010, 03:30 AM
madtexan's Avatar
madtexan madtexan is offline
Mine didn't clear my rollers so I was told to leave it off. It helps to deflect oil onto the oem rocker arm pivot balls. That's what I understand but I could be wrong.
Old 06-11-2010, 04:17 AM
PaulatFast PaulatFast is offline
Pretty well everything is covered correctly above. To the best of my knowledge anyway.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 06-17-2010, 09:33 PM
goatwgn goatwgn is offline
I have only seen this on a small percentage of Pontiac engines. It is an oil deflector, and it isnt really necessary. I would just leave it off. Most 1967-76 valve covers have drip deflectors over each rocker arm anyway. If you are concerned about oil staying on the rocker and not overshooting it, you can use crane "cool nuts". They are polylocks with grooves made in them for oil to run down.Summit and Jegs carry these.
Old 06-18-2010, 07:28 AM
2002Z4CSS's Avatar
My 1969 428 4 bolt main has those deflectors.
1971 Pontiac GT-37
Old 06-21-2010, 09:17 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
File it in the round file. Useless extra weight. Before I knew anything about my car I had mine brazed where it had cracked, told some Pontiac people about that and they laughed. It really just gets in the way.
TigerEFI.com (Classic Pontiac Fuel Injection)
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
Old 06-26-2010, 09:30 AM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
Years ago I had a terrible rattle underneath my valve covers on my '69 GTO,took one side off and that baffle was all cracked and broken up?I ended up taking both sides off the heads!
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 06-26-2010, 11:42 PM
1978 T/A's Avatar
I was hearing a clatter from time to time coming from the left side of the motor. Maybe this could have been the cause? Either way I don't think its going back on!
Thanks guy!
