Old 06-16-2010, 06:07 PM
First Bird's Avatar
First Bird First Bird is offline
Default What Reinforcing Ring? Smaller Crank Pulley
What have you guys done to add a reinforcing ring to these smaller pulleys? I am installing 6" diameter aluminum pulleys on a 455. The stock Reinforcing Ring (RR) does not fit - too wide. I searched the Forum archives without answer. I plan to keep the RR I have behind the pulley since it aligns the pulleys perfectly. But I understand I need the RR in front too. Thanks!
- Tom
Old 06-16-2010, 08:38 PM
BVR421's Avatar
BVR421 BVR421 is offline
It goes between the pulley and the damper
Bolts and washers only on front side
Old 06-16-2010, 09:26 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
you have to remember, the factory reinforcing ring was designed to be used with a factory spun metal pulley ( or pulleys if you had AC ).
going to something different, in this case aftermarket aluminum ones, changes things.
best to call the maker of the pulley and ask what they want/require.
if they're making them for pontiacs they should know the diameter of the factory reinforcement ring. if it doesnt fit that would mean two things:
it's not needed. or. they have no business making pontiac specific pulleys.
costs too much
Old 06-16-2010, 09:31 PM
no, they dont.
the factory rings were placed on the outboard side of the crank pulley(s). they were there to keep them from ripping off the bolts.
if you need the ring placed between the pulley and the balancer to align the rest of your set up, something is wrong. wrong brackets, pulleys, aftermarket balancer, etc.
costs too much
Old 06-16-2010, 11:05 PM
First Bird's Avatar
Crank pulley has two bolt patterns. Bought near new off eBay, so manufacturer unknown. Aftermarket balancer and water pump. Spacing is great with stock RR between balancer and pulley. So it looks like I need to find or make a second smaller RR to fit between pulley and bolts. Thanks for the advice.
- Tom
Old 06-17-2010, 07:44 AM
cnc's Avatar
cnc cnc is offline
Yep ring goes on the outer side of the crank pulley bolts got through the ring and the pulley
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 06-17-2010, 08:35 AM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
Installed like that it is not a reinforcing ring, it's a spacer. The RR goes on on after the pulley is set on the balancer. The bolts sandwich the pulley between the RR and the balancer.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 06-17-2010, 12:23 PM
dadsformula dadsformula is offline
There is a use of the spacer between the Balancer and pully. If you are
using an setup from an AC Car in an non AC appclication. The Spacer (extra one)
can be used in place of the AC pully. You should also use another one in front
of the Pully. This may seem unnessisary, but that 1/16 of an inch is needed
to correctly space the pulleys in this application.
Old 06-21-2010, 12:18 PM
First Bird's Avatar
Here's a follow-up on the thread. I emailed March Performance:
"Do I need a reinforcing ring for my aluminum crank pulley? The stock pulley had one between the pulley and the bolts. If I do need one, where do I get one to fit inside the smaller diameter aluminum pulley?"
March Reply:
"No, our pulley bolts directly to the balancer, no ring has ever been needed. Might have to check with balancer company to make sure since its an aftermarket balancer. Thanks, MP"
I'm not sure the person at March understood the exact location of the reinforcing ring, but "No ring has ever been needed." is pretty definitive.
Now, is this a March pulley? As good as? Cheap, soft Chinese crap?
- Tom
Old 06-21-2010, 03:38 PM
74Grandville 74Grandville is offline
I believe there is a different style ring that is samller. it may fit in there as it's not much bigger then the bolts. I'm not sure what years use them though, if it's an older or newer design.
Old 06-21-2010, 04:06 PM
73FIREBIRD's Avatar
73FIREBIRD 73FIREBIRD is offline
I make all my own pulleys & am a machinist. From the pictures it looks like the back wall thickness is about 1/4 inch thick. I make mine a little thicker but I would say you will not need the RR inside the pulley
Old 06-21-2010, 04:15 PM
First Bird's Avatar
Wall thickness is 0.250". Good eye there 73Firebird. Thanks for the analysis.
I'll look around for a smaller ring as you suggest 74 Grandville. If I find one easily I might use it just for overkill. If not, it's nice to know that a guy who makes pulleys wouldn't bother. Thanks for the input guys.
- Tom
