Old 06-18-2010, 06:09 PM
TinjunTribe's Avatar
TinjunTribe TinjunTribe is offline
Default 69 GTO Rear End Width
Seems like I saw the # in a thread a while back.....but I've searched and cant find.....
Anyone know the width of a stock 1969 10 bolt rear (axle flange to flange)?
Reason asking is I am about to purchase wheels, and the rear on my car is a 12 bolt posi. I know what backspacings work with 15x8 rim and 276/60/15s on a stock rearend (4.5") car.......but I'd like to compare the width of my 12 bolt rear vs. stock to ensure correct backspace on rim (if I need to compensate).
Thanks.
Rust makes it lighter
Old 06-18-2010, 11:16 PM
jeffgoss's Avatar
jeffgoss jeffgoss is offline
68-72 rears should be 55 1/2" from the inside of the brake backing plates.
64-67 is 1" narrower at 54 1/2"
No difference from 10 to 12 bolts.
Hope that helps.
Jeff
1968 GTO
400 4 speed 3.55 posi
Old 06-23-2010, 09:53 AM
Default Rear width
I received this # from a member here:
61" to 61.25" drum to drum
in case anyone else ever needs to know......
