Old 06-21-2010, 02:50 AM
Patina Tiger's Avatar
Patina Tiger Patina Tiger is offline
Default DISTRIBUTOR not able to be removed from block
Have a 68 400 engine and the distributor is not able to be removed. The gears un-mesh fine but am only able to lift the shank about 1 to 1.5" up before it binds. Cannot rotate the distributor body either at this point. This should just lift up and out. Is there a rubber O ring or oil seal in the way?
Thanks for the insight
Alex
Old 06-21-2010, 07:08 AM
steve v's Avatar
steve v steve v is offline
No O ring but if it has any miles on the engine it probably has a carbon gunk buildup on the distributor body that resides inside the block.
Take a can of carb cleaner & spray it between the block and dist body. It will help if you lift-twist-push down the dist as spraying. This will break down the carbon buildup on the dist & it should come loose in 2-3 tries.
Old 06-21-2010, 07:25 AM
2002Z4CSS's Avatar
Yep, that usually will fix this concern.
1971 Pontiac GT-37
