Old 06-22-2010, 07:26 AM
mrgrinch88 mrgrinch88 is offline
Default 69 GTO rear spoiler hole locations
Can anyone out there help me find a template to locate the holes for the spoiler on the trunk lid for my 1969 GTO Convertible or do you have the dimensions from the bottom lip of the trunk lid to the bottom of the pedestals?
Old 06-22-2010, 03:20 PM
69Customs's Avatar
69Customs 69Customs is offline
If you do get dimensions or a templete, please double check all dimensions before drilling. Some of the aftermarket spoilers are slightly different.
When I put mine on I first got dimensions off this forum, which were close but not exactly where my parts place spoiler studs were. So I called parts place and they instructed me that it is better to eyeball location by going off the studs on the spoiler by just sitting it where it looked correct and marking with a marker, drilling a small location hole then enlarging it.
The factory deck lids always stuck out at the bottom corner about 1/8 inch too far from the right corner of the body from the factory, which means the spoiler needs to be slightly adjusted to look straight on the car. eyeballing it makes it look straight and perpendicular to the body.
So if you go strickly off the deck lid it may not look straight on the car.
Thats just what I ran into.
Old 06-22-2010, 03:32 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
The converible spoilers are different than hardtops so double check everything before drilling.
That said, the factory used embossed ribbing on the underside of the rear decklids and if you drill through those holes in the center, you should be spot on for placement.
If your decklid is an early one without the Judge spoiler holes then your going to need a template.
John
Email [email protected]
My Website www.minnesota-muscle.com
