Old 06-24-2010, 10:01 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Default 68-69 hideaway experts question
O.K. guys , on the 68-69 hideaway's there is a stop located inboard and just below the inboard door pivot bolt. The door hits this in the open position. I think it is rubber,and has a sleeve through it. Anyone know the dimensions of the rubber ? The sleeve is + - .380 and measured an almost virgin one that had some cracks in it at .800 to .890 OD. Width could be 1/2 to 9/16 . Don't see them available repop so going to make up my own and wanted to verify dimensions. Will post pics when camera is charged,,, Leo
Leo
Old 06-25-2010, 10:46 AM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
PY # - RPF31AB
10 bucks for the pair.
sorry, no measurements, mine were torn to bits.
edit - while i'm sure you could probably use any old rubber hose that "fit", after all, that's all it is. however, if you spend time searching for the exact type you could easily burn 10 bucks in gas driving around looking for it, not to mention the cost of your time doing so, when that time could be spent on other more productive projects!
costs too much
Old 06-25-2010, 05:27 PM
6869GTO's Avatar
Thanks rolling money pits, didn't know they were available . PY shows them currently not stocked unless you buy the door pivot bolts as well in kit form. Got some neoprene hose at work with 3/8 I.D. x 3/4 O.D. that I"ll part off and try , not to concerned on correctness of material just want size close. Thanks again.
Leo
