Old 06-27-2010, 09:16 AM
TxGoats's Avatar
TxGoats TxGoats is offline
Default oil pressure ?
Ok folks tell me what this could be. On my '68 GTO the oil pressure fluctuates from 30-45psi back and forth. This has happened before, I changed the oil and it didn't do it again for over a year and now it is happening again. I think it is due to some trash somewhere in the engine and partially blocking the oil pump pick up but I don't know.
I can change the oil and it will stop, any ideas? The engine is a 1969 400 with kaufmann aluminium heads.
'68 GTO 4 speed
Life is short, don't waste time worrying about the small stuff!
Old 06-27-2010, 08:22 PM
GTOBOB's Avatar
GTOBOB GTOBOB is offline
There is a check valve and spring in the oil filter housing. I would take a close look at the spring. If it has broken it will cause the valve to open and close erratically, causing the condition you describe. If the filter is new, the pressure at the valve will be lower. As the filter collects more and more debris, the pressure at the relief valve will increase to a point that the valve will "flutter", causing the gauge to do the same.
Hope This Helps,
Bob
"It won't take long, and it won't cost much."
Old 06-28-2010, 12:47 PM
TxGoats's Avatar
Thanks, I will check it when I change the oil
'68 GTO 4 speed
Old 06-28-2010, 08:49 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Why not change the filter before you drain the oil to see if the bypass spring like GTOBOB said or filter is the problem? If it still fluctuates and you drain the oil and refill and alls fine youll have narrowed it down.
Leo
Old 06-28-2010, 09:11 PM
TxGoats's Avatar
Sounds good, getting ready for 4th of July party and I won't be able to get to it until next week. Thanks for the ideas.
TG
'68 GTO 4 speed
Old 06-29-2010, 07:09 AM
2002Z4CSS's Avatar
Might be just a bad sender. Put a mechanicle oil gauge on it and see what the pressure really is.
1971 Pontiac GT-37
Old 06-30-2010, 12:40 AM
What time is the party??
Old 07-01-2010, 09:34 PM
marauder's Avatar
marauder marauder is offline
Mine is doing something similar but varying almost the entire range.
Curt
'69 GTO Ragtop, 455, RA, KRE SD Perf ported heads and "old Faithful" cam, Sean Murphy Q-Jet, Tremec 5spd, Moser Trutrac 3:73, Hotchkiss, Speedtech, Wilwood
'64 Lemans Convertible, Tremec TKO600
