Old 07-05-2010, 06:24 PM
rad400 rad400 is offline
Default water pump pulley
What can I use to shim my wp pulley out about a 1/2"?
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 07-05-2010, 06:39 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
I've used fan spacers behind the pulley in the past. I don't know if they are offered in 1/2" but it's worth a try to look since they always seemed to work well.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 07-05-2010, 06:57 PM
Fishin2Deep4U's Avatar
Fishin2Deep4U Fishin2Deep4U is offline
I may end having to do the same thing. Luckily, I work in a machine shop. If I can dig up a piece of stock, I want to turn one out of aluminum.
I am trying to adapt a 70 and up water pump pulley onto my 8 bolt pump setup. Since I can't seem to find the "correct" pulley to speed up the fan.
Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears)
Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On!
Old 07-05-2010, 09:25 PM
66bonne's Avatar
66bonne 66bonne is offline
Water pump pulley spacers should be available at your local auto parts store.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 07-05-2010, 10:13 PM
Pontirag Pontirag is offline
a single spacer 1/2 inch thick is much much better than several of those stacked shims. better yet is the correct combination of hub, pulleys and accessories
