Old 07-10-2010, 02:36 PM
etennett etennett is offline
Default Install Remote Solenoid - Instructions
Could someone point to me a link on the steps to install a remote solenoid? I have a stock 68 GTO and am trying to solve my hot start problem.
eric
Old 07-10-2010, 03:06 PM
motor29's Avatar
motor29 motor29 is offline
I went through the same hot start problem with my 69'. I went to a high tork mini starter, that crapped out real quick. Finally I bought a stock style starter and rigged a heat shield to keep the heat off the solenoid. I have no problems starting the car even after running for over an hour. I did the research on the remote solenoid and seemed it was more trouble than it's worth.
"One dog is goin one way , one dog is goin the other, the guy is looking like what do you want from me"
Old 07-10-2010, 05:25 PM
Kitch428m21's Avatar
Kitch428m21 Kitch428m21 is offline
Pontiac hot starts.doc
1970 Burgundy GTO hardtop. CVMS built 455 4sp.
May the Torque be with you!
John.
Old 07-11-2010, 10:42 AM
Originally Posted by Kitch428m21 View Post
Than you both for the info!
eric
Old 03-17-2024, 01:50 PM
Here is what I ended up doing to correct my hot start problem. It worked perfectly on my factory starter. Full 12 volts to original starter. Cranks every time. I have the relay switch bolted to the bulkhead just under the voltage regulator. At some point when I retire I’ll chase down where I am losing voltage in the old wiring (I have a feeling it’s the bulkhead connector).
eric
Old 03-18-2024, 08:26 PM
Here’s what I did to have a full 12v to factory starter. Some day I’ll track down where I’m losing voltage but for now no hot start problems with original starter/solenoid. I ram new purple wire off the neutral safety switch to a relay.
eric
