Old 07-13-2010, 08:06 AM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Default picture of trunk weatherstrip needed
Does any one have a picture of the trunk weatherstrip installed on there 69? I want to make sure mine is in correctly before I glue it thanks!.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 07-13-2010, 11:18 PM
68pongto's Avatar
68pongto 68pongto is offline
I can try to get some pics tommorow. You wouldn't believe the number of people that put it in upside down! I've even seen it upside down on concourse cars at the nationals! Scott
Old 07-13-2010, 11:37 PM
n20ta2's Avatar
that would be great,this car was a basket case so I had no reference.
Old 07-13-2010, 11:40 PM
P Glade P Glade is offline
Here you go:
Patton Glade
70Post Restorations
Austin, TX
64-72 GM A-Body Gas Tank Pads
http://classicoldsmobile.com/forums/...tion-item.html
Old 07-14-2010, 06:48 PM
n20ta2's Avatar
so it curves out away from the trunk opening?how about the lip does it go under or over the trunk flange?
Old 07-14-2010, 09:05 PM
Yes---the top edge points outwards as you asked.
On the two lips about midway down....I'll have to check on a car here. Have temporary access to a computer right now as mine crashed so it may be a bit 'til I can check and respond.
Maybe someone else can pipe in in the meantime.
THanks
Patton Glade
70Post Restorations
Austin, TX
Old 07-17-2010, 09:07 AM
PontGuy's Avatar
PontGuy PontGuy is offline
Not sure if you have it in yet or not, but the cross section pic provided is very good and you should find it very easy and logical when you actually go to install. The rubber protrusion fits under a metal lip on the inside and the seal curves away from the trunk opening as mentioned.
Be sure to carefully inspect the gasket channel all the way around and repair any holes you find. Water will find its way even through a small pinhole under the gasket.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 07-17-2010, 12:47 PM
n20ta2's Avatar
yes its installed picture helped a ton thanks,new mexico car so no rust and it was just painted a month back.Im just assembling it now.
Old 04-29-2015, 01:38 PM
Barrier Blue's Avatar
Barrier Blue Barrier Blue is offline
Smile
Thanks for the picture! I was trying to install it wrong.
When I'm paid, I always follow my job through...you know that.
http://www.youtube.com/watch?v=Al2b-...eature=related
Old 04-30-2015, 08:33 AM
rickw rickw is offline
I did'nt know it needed to be glued. I've done a few and just forced them in...
