Old 07-13-2010, 05:25 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Operation Pinks or Bust
Well...since I have one month from today, figured now is a good time to get motivated and swap motors, transmission, converter, ignition, carb, and who knows what else.
I hope to have it ready for Friday night drags this Friday for initial testing.
ID:	211813   Click image for larger version
ID:	211814   Click image for larger version
ID:	211815   Click image for larger version
ID:	211816   Click image for larger version
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 07-13-2010, 06:15 PM
screamingchief's Avatar
screamingchief screamingchief is offline
They may (or may not) ding you during tech for not having that poly seat back braced to the roll bar (crossbar).
I guess I must've forgotten to mention that in your roll bar thread...
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 07-13-2010, 06:45 PM
Johnny406's Avatar
Bret P.
I'll make one this week, kinda like the one I made for the vega project. We just came home last night from our Colorado "staycation" so I have a l-o-n-g ways to go.
Thanks for telling me about those rockerbars. We took your suggestion and installed a pair. Between those and the subframe connectors and aluminum mounts, she should be quite stiff.
Old 07-13-2010, 06:53 PM
Ron H's Avatar
Ron H Ron H is offline
Is your shoulder harness a Y type? Those won't pass anymore either.
68 Firebird
Are you running with the wind or breaking it?
Old 07-13-2010, 07:10 PM
Johnny406's Avatar
No, it's a two strap harness, I'll mount that this week as well. I was very happy that I received it in June and it was made this July.
The black harnesses you see are coming out as well.
Old 07-16-2010, 08:59 PM
67bonnie455 67bonnie455 is offline
Default Cylinder heads
Hey, got any pictures of Pontiac Gregg's bad ass heads? What valves are you running?
Any updates on the progress?
I so want to see a Pontiac in the finals. Problem is, you never know exactly what time bracket they are going to take. You could be too fast or too slow.
On the 81 Bird, Please put a Poncho in it!! Too many half breeds around.
Best of luck!!!!
Old 07-16-2010, 10:43 PM
dda72's Avatar
dda72 dda72 is offline
You'll get it ready in time. Good luck Johnny!
Old 07-17-2010, 12:42 AM
Johnny406's Avatar
Best of luck!!!!
I posted some pics of the heads posted here. The valves are turned down bbc valves 2.19 on the intake.
Unfortunately I have run out of time and $$ to use those heads for pinks as I still need custom pushrods for them. Plus I will need to get the northwind intake milled down to fit. I just got the solid ultradyne cam and lifters this week (Thank you Greg!!), if I had another month, they would be on the car but I really need to get it together and do some testing and work out the bugs. I don't want to be doing a TnT at Pinks. I also need bigger headers as well, those exh ports are b-i-g.
I reinstalled the XE294 cam which had previously been degreed and used my old 260cfm heads with the matching pushrods and 1.5 H/S rockers.
Motor is in, I have been working on fabbing the alt bracket as I will be using the Moroso water pump motor and a electric fan. I'll post some pics shortly, I have the port matched crosswind intake with my custom Holley 850DP on it and the 125 powershot plate. I still need to put in the ignition, I'm going to a Dave Ray magnetic trigger distributor.
Pictures coming soon...
Old 07-17-2010, 12:43 AM
Johnny406's Avatar
Thank you!! Pinks is Aug 13-14, I want the car on the track next weekend.
Old 07-17-2010, 12:58 AM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
Good Luck Johnny hope you win some cash...
Old 07-17-2010, 02:21 AM
Johnny406's Avatar
Thank you Polar!! Those motor mounts I got from you were great. I dropped the motor in the car in under 30 minutes with those.
I got alot done, all I need to do now is hook up the shifter linkage, make a return spring bracket, fill fluids, and install the ignition system. I plan on cranking it tomorrow, not thrilled about the heat, we will be in the 90's again tomorrow.
Here are a few pics
ID:	212252   Click image for larger version
ID:	212253   Click image for larger version
ID:	212254   Click image for larger version
ID:	212255   Click image for larger version
Old 07-17-2010, 02:25 AM
Johnny406's Avatar
And a few more pics...
I can't wait to get both cars running...AT THE SAME TIME!!
ID:	212257   Click image for larger version
ID:	212258   Click image for larger version
ID:	212259   Click image for larger version
Old 07-17-2010, 09:25 AM
uforacing's Avatar
uforacing uforacing is offline
Ya could ask for help. There are some that are local that have a clue. Drop me a PM sometime.
72 GTO 400-M20 Lucy Blue
86 2+2 Black
09 G8 GT red
08 Torrent GXP (wife's)
09 G8 ST (UTE) black
A pissed off fat house chimp on dope would be a lot more deadly.
Old 07-20-2010, 01:31 PM
Johnny406's Avatar
If you didn't see on my other post, I found the oil pump was stuck when I went to prime the motor. Of course, everything was done but the ignition. I pulled the motor out yesterday morning and dropped the pan. I was expecting to see the drive rod stuck to the side but nope, everything was right where it was supposto be, the pump is siezed. I went ahead and pulled the pump and pan off the 406. That pan is a Moroso 7 quart and I know that pump works so on it went. I got the motor back in last night and I'm finishing the rehook up process now. I'll probably wait until tomorrow morning to fire it up and break in the cam as we're going to hit the upper 90's today.
Old 07-20-2010, 01:33 PM
Johnny406's Avatar
Please learn from my goof, no matter who builds your engine, MAKE SURE YOU CHECK THE PUMP BEFORE INSTALLING, I won't forget that ever again...
Old 07-20-2010, 10:53 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
was this a new pump or one you had used before?please let us know what bound it up if you get a chance.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 07-21-2010, 09:30 AM
Johnny406's Avatar
This pump came out of the 406, I know it works and the pickup was already welded on. It was making 40 psi with my 14v battery drill last night while I primed the motor.
I took the siezed pump to the speedshop/machinist yesterday. We pulled the bottom plate and no debris (as expected, it was never used). The driven rotor popped out pretty easy but the brive rotor needed to be beaten out. My new replacement pump will be here tomorrow.
Old 07-23-2010, 12:50 AM
Johnny406's Avatar
She fired right up and ran well for 12 minutes when one of the heater hoses to the back of the head blew off (5/8 line on 1/2 nipple didn't hold).
I was surprised on how loud it wasn't. The 406 with the XE274 was louder than the 463 with the XE294.
I'll finish the break in tomorrow morning and time it. I have 112 race gas in it, wanted to keep it cool for the run in. She stayed at a constant 190 degrees. Initial oil pressure was 65lbs cold and stayed around 50lbs once warmed up.
Old 07-29-2010, 03:13 PM
Johnny406's Avatar
I got the cage painted and the pads installed. The harness is in as well. I'll take her out tomorrow for initial shakedown runs. If all goes well, I'll take it to Earl Scheib for a paint job.
ID:	213531   Click image for larger version
ID:	213532   Click image for larger version
ID:	213533   Click image for larger version
ID:	213534   Click image for larger version
Old 07-29-2010, 03:29 PM
66bonne's Avatar
66bonne 66bonne is offline
You're making great progress !!
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
