Does anyone have a pic of the Z-bar on a 68-69 A-body at rest? I need to see how far forward it goes. A measurement of how far forward the arm is from center of the Z-bar to the end of the arm would be great also.
Thanks |
Hope this photo helps this is all I have access to right now.
Thanks motor29, do you by chance have a pic of the lower arm that goes to the clutch? Maybe from the side so I can see how far forward it sits?
In the pic it looks like the upper arm is straight up, am I correct? My Z-bar looks different is yours stock or aftermarket? |
Here are a few more photos from the backside where the z-bar meets the engine boss. I think I got this repro z-bar kit from Ames, the one that was in the car was out of a full size Pontiac but was completely wrong. Once I installed the new z-bar it did sit a little differently at rest it is as you see in the first picture. Hope this helps.
Reminds me to add grease to mine!
Curt '69 GTO Ragtop, 455, RA, KRE SD Perf ported heads and "old Faithful" cam, Sean Murphy Q-Jet, Tremec 5spd, Moser Trutrac 3:73, Hotchkiss, Speedtech, Wilwood ![]() '64 Lemans Convertible, Tremec TKO600 |
thanks motor29
Factory original 1969 GTO, crappy camera. I can take more pics or pull off the z-bar if it will help. Let me know
Thanks Batman,
Heard you stopped by to pick up the rods & got to see the other Bat cave |
yep, let me know if you need z-bar pics. I'm about 4 bolts away from an unobstructed full side view,
