Old 07-27-2010, 05:08 PM
6T9GTO's Avatar
6T9GTO 6T9GTO is offline
Default 01 ic EX Help Needed
Maybe someone can help me out...
I have a 01 Civic EX that keeps throwing the CEL. I get codes P0300-P0304 which are random misfires on all (4) cylinders. It initially throws a P0301, which is a misfire on cylinder 1. After a little more driving, the others codes are set. I have put in a new set of plugs. I also switched the coil packs around, but cylinder 1 always show up first.
I have read numerous internet postings, but none of them can give a reasonble answer as to why this is occuring. I have read: coil packs, spark plugs, EGR valve, crank position sensor, knock sensor, no compression, bad injectors, bad head gasket, bad fuel pump, bad injectors, etc.
This car does not a separate fuel filter, just a sock integrated with the fuel pump in the tank.
The only diagnostic tools that I have are a code reader and a good multi meter.
Can somenone tell me how to check the injectors with the multi meter? I guess I can get a loan a tool from Autozone to check the fuel pressure.
This is the second time that the car has done this. When it did it prevously, I took it to the Honda dealer with the CEL on. They claimed that they couldn't get any codes out of it and charged me $80, but the CEL stayed off for about six months.
I have had no other problems with this car (195 k miles) which I bought new. I don't want to pay the stealer to chase parts to fix this. Any help would be appreciated.
Thanks, Bill
Old 07-28-2010, 01:11 AM
Stuckinda60s Stuckinda60s is offline
I would check the fuel pressure, if it's marginal it can give you random misfires. The fuel pressure can give it to you in a couple of ways. Low pressure or a leaking diaphragm. The first will go lean and the latter rich.
This is a generic answer, not specific to Honda Civics. But, it's a good place to start.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 07-28-2010, 11:45 AM
6T9GTO's Avatar
Rich,
Thanks for the response. I'll check the pressure and go from there.
-Bill
