Old 08-01-2010, 06:47 AM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Question Endura Bumper Emblem
How is the Pontiac Emblem attached to the endura bumper?
Old 08-01-2010, 09:25 AM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
If its a 1968 Bumper there is 2 holes in the Endura Bumper that the emblem fits thru and there is 2 pins on the back side of the emblem that will slide thru the holes and there should be 2 retainer nuts that will screw onto the end of the threaded pins.One thing to consider is a 1969 Endura bumper will fit a 1968 GTO/LeMans so if You happen to have a '69 style Endura bumper there won't be any holes there to mount an emblem.
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 08-01-2010, 10:46 AM
68pongto's Avatar
68pongto 68pongto is offline
There are no nuts that hold it. The shafts are threaded, but you basically push the emblem into endura for a snug fit. The nose has a larger hole neer the surface to fit the shouldered part of the emblem and the deeper part of the hole is 1/4". You can make a 69 nose into a 68 by drilling the holes. I usually put a little adhesive on the shafts since these old noses can be worn out! Scott
Old 08-03-2010, 09:16 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Yep,what he said,x's 2
Leo
