Old 08-03-2010, 01:57 AM
Flowjoe's Avatar
Flowjoe Flowjoe is offline
Default '69 HD rear end
On a stock HD Safe-T-Track rear axle (on a '69 Goat) the ring gear still has 10 bolts - correct? What is the diameter of said ring gear? How does it differ from the standard Safe-T-Track rear?
Old 08-03-2010, 06:51 AM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
What I believe to be true -
Same ring gear as non-HD.
4 pinion diff (non HD has 2 pinion)
HD has forged axles - rougher texture with slightly tapered ends - stronger than cast axles, which are smooth but look slightly beefier.
Nodular iron housing - denoted by "N" cast into nose of housing.
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 08-03-2010, 06:54 AM
2002Z4CSS's Avatar
The ring gear diameter should be 8.2".
1971 Pontiac GT-37
Old 08-03-2010, 10:45 AM
Flowjoe's Avatar
Scott
Thanks you - very helpful
Old 08-03-2010, 10:48 AM
Flowjoe's Avatar
That's what I thought. - thanks
OK, anyone, what's the diameter of the pinion shaft on the HD? On the standard? I am pretty certain they are larger than the Chevy 8.2 which is 1.438".
Old 08-03-2010, 10:54 AM
webfoot's Avatar
webfoot webfoot is offline
I have a 3.90 pinion/yoke in my garage, and it is definitely bigger than the chevy 8.2.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
