Old 08-04-2010, 02:28 PM
69*Goat's Avatar
69*Goat 69*Goat is offline
Default Lots of issues to deal with..
OK:
I have had my GTO on the road for a little over a year. Before I did the motor swap, I used to drive this thing as my daily driver. Anyway, about two years ago my neutral safety switch went out, so I was having to put it in neutral to start it. Now, I am having to put the shifter in reverse to start it. I am guessing that this is caused by a worn out steering column(Maybe, Maybe not) I am getting intermittent no start issues, no power at all, where I can go out and wiggle the wires that go to the starter', and it starts fine, and all electrical works (I know, probably time to replace the engine harness). I am also getting intermittent radio cut out issues, which I think has something to do with the above stated power issue.
I am really not looking forward to replacing the engine harness, and the dash harness, but I do not see anyway around it. What could be causing the starting in reverse issue, I know the neutral safety switch probably has something to do with it, but I also think the original steering column may have something to do with it also.
Have any of you had this same problem with your 69'?
Also, where is the neutral safety switch, and what replacement wiring harnesses do you guys suggest?
Thanks for the reply's
Old 08-04-2010, 09:58 PM
oxfordsteve oxfordsteve is offline
Send a message via Yahoo to oxfordsteve
Originally Posted by 69*Goat View Post
OK:
I had this problem. Parked on a hill with no parking break and had to pull the shifter really hard to get it out of park. The linkage going from the tranny to the column was pulled out of adjustment and it caused the switch on the column to no longer be in synch with the shifter. If you can reach up on the collar on the column and twist it slightly while turning the key and get it to crank then you have found the problem!
