GTO upper and lower control arms
Have been reading the different options for the rear control arms for my 66 GTO (search function) but have not seen anything on UMI. Has anyone used there set up in the rear?............................................. ...........................Mark
Type in UMI performance............
I have BMR Fabrication's rear upper and lower parts.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I am leaning towards the Edelbrock uppers because of there linear pivot point on there upper arm and get the boxed lower. Was just asking about the UMI unit it looked pretty nice.............................................. .................................Mark
what is a "linear pivot point" ?
www.pro-touringf-body.com |
I have BMR, and they are nice pieces.
PT 79 I'm sorry I meant Spherical ball assembly with Delrin bushings. I think they would eliminated any bind while preloading the rear. Mark
ah! ok, check with Ram air restoration
Thanks but its for a 1st gen GTO.
Do yourself a favor before you buy,and check out Spohn Performance.
Reasonbly priced and very well made.I have the Rear Lower and Upper Arms from them.Really nice units. |
I have all UMI lower and upper control arms on my 66 post. Also went with the adjustable. They fit great. Now, when I bought mine, I called UMI explained what I had, and they gave me the correct part numbers which I used for ordering. They also wanted to know if i upgraded the rear end, which I did. So, a call to them may be a lot of help. I also have a couple of guys I know who use their stuff on Pontiac's. Nice people to deal with, and they seem to enjoy taking time to chat and get things clear.
Mike
Build it fast, build it right, hold On TIGHT !!! |
Me Too.......with the braces
PMT...can find them on EBAY. Mark is awesome and the best customer support hands down.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
I have PMT lower control arms, and they're great. Well made, reasonably priced, made in the USA, and very good customer service. I'll get my uppers from them after the economy improves (hurry up 2012!!!).
Sammy 1967 Lemans: 455 swap in progress (stock crank, stock rods, TRW slugs, mildly ported 6x heads, Stump Puller hyd roller, 1.5 PRW aluminum rollers, Comp hyd roller lifters, Performer RPM, q-jet, RA exhaust manifolds, 2 1/2" exhaust, ebay HEI), 200 4R, and some suspension stuff |
