Old 08-13-2010, 09:05 AM
rohrt rohrt is offline
Default 68 cam install pull engine or not
Can the cam be changed with the engine in a 68 bird or does it make more sense to pull the motor verses the amount of work to remove front end parts.
Can anyone speak from experience?
Old 08-13-2010, 09:50 AM
68bird400HO's Avatar
I was able to do a cam swap in my '68 with the motor in the car. You need to pull the radiator to make room for the cam going in and out but thats not a big deal at all. It was close but there is enough room to do this.
Old 08-13-2010, 10:10 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Talking
i just did a Melling spc-7 (068) cam swap in my 68 bird and yes 'the rad has
to come out to give clearance for cam removal. took 5 hours total and my
back was sore by the time we fired it up.
use good breakin lube and enjoy!!!!!
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 08-13-2010, 02:02 PM
Great, thanks for the input.
My brother put one in his 76 T/A and nearly had to tear the whole front end apart to get his in..
Old 08-13-2010, 03:51 PM
The trick for the 76 Bird is to loosen/disconnect the center upright support that holds the hood release.
It will back off enough to pull the cam.
Old 08-13-2010, 10:00 PM
Cammer-6 Cammer-6 is offline
If I remember right pulling motor mount bolts and jacking the motor up will help too.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-14-2010, 08:08 AM
tjdjr's Avatar
tjdjr tjdjr is offline
Take out the hood latch support as well.
