The original e-brake cable on my 69 bird was hacked by previous owner. I have removed it but I'm having trouble feeding the new one into the d-side floor board. Does the d-side inner fender have to be removed to install it or is there another less painful way?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
I removed all the inner fender bolts and moved fender to give space- without removing it from the car. Then, I put a fish wire into the hole from the cabin side, hooked the e-brake cable, and snaked it into the cabin. Worked like a charm. I connected all the cables (In-line Tube) and did a preliminary adjustment. I need to adjust them a little tighter and I'll be set.
