Poverty cap diameter? Need size...
I'm looking to verify the diameter of the standard rim poverty caps. IIRC the stock steel rims I have are 14" X 7" from a 1965 GM car. Do I just measure the inner circle where the caps attach?
I'm trying to have a cruise/show set of wheels/tires to make the car look more factory. I'm not worried about factory correct just a more stock looking appearance. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
Dish size...
Hope this helps, below is a stock 66' Rim & Dog Dish/Poverty Cap.
The rim is 14X6 Width measured from the inner bead/lip to lip. Cap ID is aprox 10.25. Note the 3 mounting points on the rim, Not sure if all stock rims have them.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 11-10-2011 at 08:29 PM. |
Thanks again!!! JD
